Thread: Quicky! Rear pads, is it the inner or outer with spring?
    Regular Member MCD's Avatar
    NE Manchester
    40 Post(s)
    Vehicle : 2007 Vectra
    Trim : SRi XP T Saphirre Black
    Engine : z20net
    Mileage : 80k
    Default Quicky! Rear pads, is it the inner or outer with spring?
    Hi guys,
    My outer pad started rattling on the rear at weekend, it looks like it has too much movement up and down. I remember when fitting my rear pads, on one pair there was a spring on the top edge of the pad, where as on the rattling neither inner or out pad has the spring.
    Without stripping down the other side too look, could some one please tell me if the inner or the outer which has it? And what is its purpose?
    Looking at my outer pad, there is a good 1mm too much up & down movement. Ive made a little brass shim which works ok for now, but i think i will buy new pads later...
    Mike
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    Presume you mean his spring -
    If so this one sits against piston on the inside of the caliper. There should be some relief grooves in the piston to accept the spring.
    May 2008
    Tyneside
    The new type of pad has the springs next to the piston. Check out this thread, explains everything http://www.vectra-c.com/forum/showth...t=67661&page=4
    NE Manchester
    40 Post(s)
    Engine : z20net
    Mileage : 80k
    Thanks guys,
    Yes its this one to which im referring! It goes on the inside piston i see! Whats wierd is thats missing from my inner pad, and is supposed to be the anti rattle spring! however, its my outer pad that was rattling... go figure??
    May 2008
    Tyneside
    Which pads did you fit, the new design or the old? The new pads have two with springs and two without. As stated the spring pads go next to the piston. With the sliding caliper it is only this pad that slides, the outer pad doesn't move relative to the caliper. HTH
    NE Manchester
    40 Post(s)
    Engine : z20net
    Mileage : 80k
    I fitted the new design, with the spring on the outer edge. But the spring has snapped of the inner pad on the passenger side... but its fine, its not rattling! Its the outer pad on the passenger side which is rattling, its as though pad is ever so slightly too small for the slots it sits in, and as such rattles up and down?
    Mike
    May 2008
    Tyneside
    The inner pad is sprung so that when the caliper piston releases after braking, the pads and discs stay "sandwiched" together which prevents rattling. If the spring has snapped I think thats your problem. HTH
    NE Manchester
    40 Post(s)
    Engine : z20net
    Mileage : 80k
    hmm, cheers!
    I was kinda starting to think that! Right, new set of pads it is then, shame! Loads on them too!
    Mike
    Just to complicate things, I recently bought a set of rear discs and pads from vauxhall
    part No V0093186300 and there are no springs on any of the pads. Price was £52.20 +vat using trade club.
    The car is 1.9 cdti.
  1. Rear, Outer Bushes, is this the right kit ? (Powerflex)
    By slot in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2012, 23:55
  2. Rear Spring Pads...
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 16th March 2010, 14:56
  3. Pair of rear outer headrests...
    By danBoy in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 31st December 2008, 22:23
  4. Mintex Front Pads, Rear Pads and Rear Discs
    By The Gas Man in forum Parts for sale
    Last Post: 6th January 2008, 00:34
  5. 2.2 SRI rear box outer skin
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2006, 19:50
what side does spring on rear pads of a 2006 Vectra rear pads go
vauxhall signum rear pads springs
