Thread: New wheels but what size??????
    norwich
    Default New wheels but what size??????
    hi all am new got my vectra 52 plate 1.8 club
    and would like to fit some rims yes i no im young so have been looking at
    18" dotz shuriken with
    fullrun hp199 225/40zr18 92w xl fitted or 17" dotz shuriken with 215/40/r17 both 5 stud so do you no if they will fit or will they rub or something cheers guys
    Regular Member mikeeaston's Avatar
    widnes
    size wise they will both fit as you can comfortably fit 19s to a veccy without them rubbing, all depends on the offset of the studs if they are for a vx then they should be ok, as far as i know all 5 stud vauxhalls are the same offset apart from the vxr8 but dont quote me on that hope this helps.
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    20in fit on the vec-c without rubbing as long as there the correct off -set.
    norwich
    wow 20" would look nuts ok so what is off set and what does it need to be? cheers for the help guys ok the offset on the 18" is 40 so what is my vectra?
  1. Changing The Size Of The Wheels.
    By Vectra Bear in forum Styling
    Last Post: 20th May 2011, 11:32
  2. 17" Wheels and tyre size 215 45 17
    By JRBVectra in forum Styling
    Last Post: 9th November 2009, 22:32
  3. What Size Wheels??
    By bigboynigs in forum Styling
    Last Post: 6th October 2008, 18:48
  4. Different Signums or Different Size Wheels?
    By dave45040 in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2007, 22:06
  5. what size wheels
    By surreyl31 in forum Styling
    Last Post: 13th May 2007, 21:53
