Thread: 2.2 Direct full throttle issue
    Cheshire
    Exclamation 2.2 Direct full throttle issue
    Evening all,
    I own an 07 Vec Estate SRI 2.2 direct, but there seems to be a little issue with it at the mo.
    When excelerating normally the car pulls through the revs OK, but when giving it some beans, the revs reach 4k and the drop back to 3.5K and then continue to pull all the way up to the redline again??
    Its really strange, doesn't feel like a missfire....
    Car is an Auto, and has just been in for the fuel pressure recall in the last fornight.
    Thanks in advance for any suggestions.
    James
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    It could be the HP pump mate but they tend to lose power at 3.5-4k and not recover.
    Cheshire
    Yeah i thought about the pump as well, but it pulls strong again after its flat spot.
    Prob need to book it in to vauxhall as its still in warranty until June, so making sure all niggles are ironed out before then!
    Cheshire
    Well car has been in today, turns out that they have identified the swirl flap issue that i have seen so many threads about!
    Good thing is they are ordering a part which will 'apparantly'' provide a permanent fix under warranty.
    Should i have noticed this? no warning lights on dash....
    Regular Member Sambor's Avatar
    Elgin
    Quote Originally Posted by Morzy View Post
    You can identifi just using Tech 2.
  1. Help please. Starting issue 2.2 Direct SRI
    By fidzer in forum Engine & Drivetrain
    Last Post: 29th June 2012, 10:16
  2. Throttle body full of oil - 1.9
    By Barlow in forum Engine & Drivetrain
    Last Post: 13th March 2012, 17:59
  3. Help ..... juddering on full throttle
    By watchman in forum Engine & Drivetrain
    Last Post: 29th September 2010, 02:06
  4. 2.2 Direct Big Issue!
    By Sambor in forum Engine & Drivetrain
    Last Post: 4th July 2010, 19:28
