Results 1 to 10 of 14
Thread: Recommend me a HID kit.
    In a house
    Default Recommend me a HID kit.
    Ok guys, I'll try and keep this short, I installed a 35W 6000K HID kit a couple of weeks ago, I had an initial problem with the headlamps strobing and giving bulb failure warnings when the engine was running, this didn't always happen / was intermittent.
    (Neither was supposed to happen according to the description / advertisement)
    I contacted the supplier who was very helpful and who sent me a pair of load resistors free of charge, I installed these and the headlamps didn't work at all !!!.
    I again contacted the seller and after advising me to remove the load resistors, they then supplied me with a set of warning cancellers, again free of charge.
    However before the warning cancellers arrived I managed to have the Xenon headlamp setting in the on board controller activated and the problem of the strobing and bulb failure warnings appeared to be illiminated.
    The only problem that I am left with now is that the HID's randomly flicker, for varing periods of up to Ten or so seconds, (Not like strobing) this can happen either when I am driving along or stationary, and may happen Two,Three or Four times in Five minutes and then not happen again for the best part of an hour or more.
    I'm thinking of sending the whole lot back to the supplier and hopefully with your good peoples guidence, getting another set that "Plug and play" without ANY problems from an alternative seller, but before I do that, do any of you guys know if fitting the warning cancellers that I have been supplied with might remedy this problem ?,
    if not and I do end up sending the whole lot back, can any of you good folk point me in the direction of a set of 35W 6000K HID headlamps that will "Plug and play" and work faultlessly when fitted to a facelift, full Canbus, 56 / 07 reg / Vectra C / 1.9 CDTi / SRI
    Your advice / comments would be much appreciated,
    Thank you and regards,
    Saxman.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I'm pretty sure you just need to fit the warning cancellers to eliminate the flickering problem.... worked for me.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    im interested in a set of hids myself so would also like a kit thats easy to fit and comes with a recommendation
    Regular Member davidlewis24's Avatar
    bridgend / wales
    hids direct i bourght 50w 6k 3 months ago no problems what so ever and mention vectra-c.com and get discount hope it helps also realy easy to install
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    I'm seriously considering this kit and will not accept any probs with it as it will go straight back if any probs.
    http://www.hids-direct.co.uk/hid-con...its-p-445.html
    Can you advise us of the kit NOT to buy?
    Are you VXR Enough
    13 Post(s)
    that kit looks to be the one fella
    Regular Member fingers66's Avatar
    Carpe Diem
    I have a 57 facelift, I bought the 35w 6K kit from hids direct, no problem at all, I didnt even need to fit the extra cancellers that are supplied with it..... I now look forward to night time driving now as I can see where Im going.
    Full Member watchman's Avatar
    Apr 2009
    Leeds
    Engine : Z28NET
    Mileage : 75000
    HIDS Direct are the ones. I've had them in over 9 months. No problems at all.
    Got these: http://www.hids-direct.co.uk/hid-con...its-p-445.html
    2007 Signum Design 2.8T
    Teapot TUNED
    Powerfold mirrors, Eibachs & Bilstein B4s, Roof rails
    11 Post(s)
    Got mine from www.hids4us.co.uk/h7.htm
    Plug and play, and touch wood, no problems so far.
    EDIT - link has been changed since I bought them:-
    http://www.sinax.co.uk/hids4us/index...&product_id=69
    guildford
    Big Dave how long have you had yours fitted?
    and has anyone got any pics they can post of the the 6000k one's
    cheers
    mark
  1. Recommend me a..............
    By keith1983 in forum Electrical & ICE (including SatNav)
    Last Post: 17th December 2011, 16:56
  2. Recommend a re-map
    By rockonoli1 in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2011, 00:12
  3. Recommend my mum a new car!
    By djr69uk in forum The 'Off Topic' room
    Last Post: 19th May 2011, 18:43
  4. Recommend me an oil
    By lizard in forum Engine & Drivetrain
    Last Post: 4th December 2009, 14:11
  5. anyone recommend a hid kit?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2008, 23:11
