Thread: Fault code reader 2003 2.2 dti needed
    Aldermaston (Berks)
    Default Fault code reader 2003 2.2 dti needed
    Hi all can someone point me in the right direction of the above, i have been looking but im unsure as to which i need, on most of the diesel 1's it states 2004 eobd but cant seem to find one that will work on my model.
    Does anyone own the same car with a code reader that actually works?
    Full Member paul.sessions's Avatar
    leighton buzzard
    you need, op-com, vaux-com or tech2
    Aldermaston (Berks)
    I have heard of op-com, however is it possible to use it with a desktop pc as i dont have a laptop, i was thinking of getting a usb extension cable and op-com is this a viable solution, car is approx 10-15ft away from pc.
    leighton buzzard
    Quote Originally Posted by mr.c72 View Post
    yeah should be fine
    Aldermaston (Berks)
    coolio thanks m8
    Nov 2009
    Norfolk
    I'd make sure you use one single usb extension cable.
    I tried using more than one when the laptop was playing up.
    Worked ok with one, but played up with more than one!
    Regular Member Innes's Avatar
    Plymouth
    I tried Tech2 but didnt work with my 2003 2.2dti SRi. Op-Com works a treat!
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Quote Originally Posted by Innes View Post
    Are you sure it was tech2? As tech2 is the snap on tool the dealers use. (Its not PC based)??? And works with every single vectra c
    But at £3000 not a lot of people other than dealers have em!
  1. What fault code reader?
    By s2yob in forum The 'Off Topic' room
    Last Post: 25th July 2011, 13:43
  2. Help! - Fault Code Reader Needed!
    By irondan in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2009, 21:39
  3. fault code reader needed near newark
    By craigbarlow18 in forum General Chat
    Last Post: 20th June 2009, 15:07
  4. Fault code reader needed in liverpool
    By jimmytarnat in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2009, 12:54
  5. Fault code reader
    By Allblackdup in forum South Wales (RO - Vacant)
    Last Post: 30th March 2009, 16:03
code reader for 2003 signum
