Thread: Newbie with wobbly rear end..!!
    Bristol
    Default Newbie with wobbly rear end..!!
    Hi all, have recently returned to the vauxhall scene with a SRi Edition 100, I'm trying to decide if there's a problem with the ride/ rear suspension.
    I've had numerous SRi's in the past but this is my first Vec C.
    Around town the ride is firm, but certain unmade surfaces make the rear feel really unsettled, and on the motorway the other day it felt so disconnected on the back end I took my foot off.
    I've jacked it up this weekend and the springs don't appear broken and no obvious leaks on the shocks.
    Any thoughts????
    Regular Member mccluskey119's Avatar
    gourock
    i've got the same problem mate dont feel connected at all over slight bumps or backroads ?? no idea either ?
    WGAF#5
    i suspect weakened shocks.... as a matter of interest what make rear tyres do you have and what pressure are you running them at ???
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Gonna disagree with ya here Dez , i'd go with knackered upper control arms.
    If you grab a hold of the top of the rear wheel (while it's on the ground) and give it a few sharp tugs, there should be no noises but if you are getting a clunking sound then i'd be replacing the UCA's hth
    Bristol
    Cheers guys, have given both the back wheels a good tug (so to speak!) and one makes no noise at all and the other is making a right old clonking noise and almost feels liek it has movement in it.
    Seems to be pointing to the UCA's so will get them changed and see what happens..
    Regular Member Jezzy's Avatar
    S.E
    I changed the upper control arms last week - couldn't believe how soft one of the rubber bushes had become. It was shocking; (see what I did there ? )
    Bristol
    Hoping I won't have to do it myself, only had the car 6 weeks so hoping the so called warranty will cover it. Bit surprised it went through the MOT though, shouldn't it of got picked up then ??
    Wonder if the wife knows how to change upper control arms?!? i'll ask...!
  1. Wobbly Knob
    By ChrisBilly in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2011, 12:23
  2. Loose/Wobbly Signum Rear Bumper
    By snapsnap in forum Bodywork & Interior
    Last Post: 9th April 2009, 15:35
  3. Wobbly Bolts
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2007, 22:10
  4. Wobbly bolts. Where??
    By freks in forum Suspension, Wheels & Brakes
    Last Post: 1st April 2007, 06:40
  5. Wobbly
    By ROB WOODHOUSE in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2006, 12:23
vectra c wobbly rear suspension
