Results 1 to 3 of 3
Thread: CD70 Display
    Leicester
    Default CD70 Display
    Can anyone advise what medium to use to clean the screen on my CD70 (nav).
    I guess that when its lit up in daylight mode it doesn't look too bad. In night mode it loses a bit of focus where the greasy/dirty marks are, but when everything is switched off it looks like an uncared for mess.
    I've tried glass wipes, dry microfibre cloths, spit, and even LCD screen spray.
    It still looks greasy when switched off. Its not inside the unit cos you can move the streaks and marks around whilst wiping.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    hard one, but a mild alcohol based cleaner may work...
    Such as Isopropyl Alcohol, as used to clean tape heads and cd lenses.
    If you have a gease problem, the alcohol or spirit based chemicals are the only adequate solution.
    I once heard that Vodka is a good grease cutter / cleaner and it is quite odourless and taint-free...
    BUT and there's always a but..
    Some cheaper alcohol cleaners leave a white powdery residue when dried.
    Do not use brake, carb or electrical contact cleaner....these are far too harsh, and may damage the delicate screens.
    11 Post(s)
    Mine was pretty filthy when I bought my Vectra. The LCD screen cleaner I bought from ALDI cleaned it up.
  1. CD70 display
    By DHobbs in forum Electrical & ICE (including SatNav)
    Last Post: 23rd October 2012, 13:14
  2. Cd70 and display question
    By RBH in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2011, 11:52
  3. CD70 and TID display is it possible?
    By Autobahn in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2010, 22:10
  4. CD70 decode and display
    By henryf in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2010, 20:36
  5. Change display CD70
    By FLi in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2007, 18:10
