Results 1 to 10 of 21
Thread: Help needed with 1.9cdti 150 juddering!!!!
    Regular Member stuart813's Avatar
    gosport
    Default Help needed with 1.9cdti 150 juddering!!!!
    Hi i've looked on the forums and heve seen the threads about this but still a bit confused. My car has a judder between 1500 - 2200 rpm and is getting worse yesterday it cut out twice at a roundabout but started fine. The judder isn't there when i accelerate but is only just noticable at idel.
    Could this be the EGR needs cleaning or injector No3 wiring???
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Sounds more like injector 3 wiring but could be egr too I would give the egr a strip down and clean via the how 2 on here then if it's still the same do the 3rd injector mod which is about 12quid to buy the kit have you got any fault codes stored as this will help mate
    gosport
    No i don't and i'm not getting and dashboard warning lights either!!
    kings lynn, norfolk
    Try the how2 on here for your egr mate as it's free and only takes a hour try it after that if no joy then do the 3rd injector mod
    gosport
    Ok will do and i'll let you know how i get on!!
    Thanks guys.
    gosport
    Well guys i gave the EGR and Boost sensor a clean and all seems well i'll have to take it on a good run and see how it is.
    kings lynn, norfolk
    good mate hope it was sorted i though egr balve at least its free and fixed now mate let us know how it gets on
    gosport
    yeah the solanoid plundger is free so didn't need to take it out.
    kings lynn, norfolk
    good if it starts doing it again then take the plunger out and give it a good clean mate has it cured all the probs then
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Mines done that and I have had the injector loom cleaned so far and it has reduced the juddering alot but it still does it.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
  1. another 1.9cdti 150 juddering.... quick check as seen stickys
    By skip85 in forum Engine & Drivetrain
    Last Post: 20th July 2012, 21:58
  2. Juddering 1.9cdti
    By Alan/1967 in forum Engine & Drivetrain
    Last Post: 9th October 2011, 17:17
  3. 1.9CDTI Clutch Juddering
    By robdd1 in forum Engine & Drivetrain
    Last Post: 30th January 2011, 21:00
  4. 1.9cdti juddering when started
    By mark-1-spark in forum Engine & Drivetrain
    Last Post: 28th March 2010, 20:33
  5. Juddering 1.9CDTi 150
    By ghostrider in forum Engine & Drivetrain
    Last Post: 11th September 2009, 23:44
