Thread: Colour Coding Mud Flaps - Help
    Full Member watchman's Avatar
    Apr 2009
    Leeds
    Mileage : 56000
    Default Colour Coding Mud Flaps - Help
    Set about trying to colour code my new mud flaps on Saturday.
    Used Halfords Plastic Filler Primer to smooth them off.
    Was working great, got a few coats on.
    Then I tried to very carefully rub them down with some wet & dry.
    Only one survived to the next stage.
    The problem was the flaps are too flexible and the paint is not. It all cracked and came off.
    Any one done this before and can offer some advice please.
    2.8T Signum Design
    Teapot TUNED
    Full Member gibbon7000's Avatar
    lincs
    what grit wet/dry did you use. min 1200
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Apr 2009
    Leeds
    Mileage : 56000
    600 just to get the stipples off.
    2.8T Signum Design
    Teapot TUNED
    lincs
    Its too coarse, it will only need 1200, you are using it wet arent you, with a drop of washing up liquid in the water? and gently rub.
    Aug 2009
    sheffield
    hi,which mudflaps are they ? the solid plastic one,s or the rubber one,s ?
    Apr 2009
    Leeds
    Mileage : 56000
    Solid plastic.
    I've got one looking good.
    It wasn't so much the paper but how I handled them after the primer.
    I put about 5/6 coats of the plastic primer filler on.
    Is that too many - it was quite thick, but it didn't seem to stick very well to the plastic.
    2.8T Signum Design
    Teapot TUNED
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    its all the silicon in the plastic i believe.. makes a right mess of the paint job as the plastic primer just falls off.. Not sure what you do about it i remember reading about it before on here..
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Soak them overnite in a bowl/bucket with a strong degreasent mixture i used jif one for all, this will lift all the oils out of the plastic.
    and still loving it
    Aug 2009
    sheffield
    hi,use a good motor factors /refinishing supplies ( where the trade goes ) to get the best products. plus they give free advise. ( they have seen it all before ) i now use a product called pro xl plastic adhesion promoter,which drys transparent and can be over coated after 30 mins ( excellent ) good results on mudflaps /mirror covers . go where the body shops buy..............
    Apr 2009
    Leeds
    Mileage : 56000
    I've ordered a can of plastic adhesion promoter.
    Thanks for the advice.
    2.8T Signum Design
    Teapot TUNED
  1. Colour coding your V
    By bigdave1701 in forum Styling
    Last Post: 13th August 2011, 11:42
  2. colour coding.
    By winty234 in forum Photoshop section
    Last Post: 26th July 2010, 18:46
  3. colour coding
    By KevinG in forum Styling
    Last Post: 30th April 2010, 17:55
  4. Colour-coding
    By jonnynufc in forum Bodywork & Interior
    Last Post: 23rd June 2009, 23:57
  5. Colour coding mud flaps.
    By rosssri in forum Bodywork & Interior
    Last Post: 8th March 2007, 23:18
