Thread: Traction control switch.
    Regular Member 2ltrT's Avatar
    North-East (Middlesbrough)
    Default Traction control switch.
    I just got the switch from my dealer, after checking that ther was a blue plug under the alarm button, plugged it in and nothing
    When i pressed the putton nothing at all happened, i was expecting the traction control light to illuminate on the dash indication its switched off, would i be right in expecting this?
    the blu plug is there and its making good contact because button lights up when headlights are on....
    help greatly appreciated,
    North east HQ
    i did this with mine mick and when i press the switch the light does come on on the dash, maybe a faulty switch where did you get it bramalls?
    i had to take mine back twice cos it wouldnt work
    Humm, yes got it from Evens halshaw (bramalls) on a66, maybe i got your old switch
    how did you diagnose the switch as faulty?
    North east HQ
    as you say the switch lit up but nothing on the dash, had to whinge a bit as they had never ordered a tc switch before and didnt even know it was a part!!!!!!!, try taking it out then putting it back in could be just not fittting properly
    I've just tested the switch with a multimeter, and it apprears to be working fine, it must be if anything a bad connection at the blue plug.
    thanks for your help chunkster.
    I've just removed the plue plug from behind the dash, and tested it by connecting pins 5 and 6, and it still didnt work.
    so the switch is ok, and its making good contact, so all i can think of is somthing is missing or it needs programming?
    I know it has traction as the light has started flashing on a few occasions.
    Regular Member Robward27's Avatar
    Witham
    Some dont work may be a tech 2 job. I can turn mine off just with the ignition. With engine running quickly turn ignition off one click and back on again keeping engine running all lights should come on and go off again except TC which will stay on and thats it! lol
    Regular Member gizmo10119's Avatar
    Cambridgeshire
    doh! ive just been and bought a switch for my sri cdti plugge dit in (def blue socket there) and nothing! can anyone confirm a way round this or does it have to go to the main diddler to be programmed?
  1. traction control switch
    By neilshaw1980 in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2009, 09:45
  2. traction control switch
    By Beavis in forum Parts for sale
    Last Post: 13th April 2008, 08:15
