Results 1 to 10 of 14
Thread: whining noise on my CDTI 150 SRI
    Sleaford
    Default whining noise on my CDTI 150 SRI
    All
    I have a 2006 CDTI 150 vectra SRI and theres a whining / whizzing noise that seems to be engine speed dependant.
    The noise is purely when you put your foot down either statically or in gear.
    Recently I have had a DM flywheel and clutch change. The turbo is operating as it should ( I think ) and economy isnt affected ?
    Any takers ???
    Karl B
    Regular Member platty's Avatar
    Jan 2008
    Paisley
    Hi mate I had a similar noise to the one you described, for me it turned out to be the aircon compressor. Try running the car with the drive belt removed, if theres still a noise it's possibly a timing belt idler or tensioner, if the noise dissapears could be drive belt tensioner, alternator or aircon compressor. Hope this helps
    Sleaford
    Thanks for your reply, With the air con compressor, would that generate a lack of cool air when the aircon is on ??
    How easy is it to get to ? is it a home job or would I need garage support ?
    Karl B
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    does it copy the engine speed or stay there when the revs drop like turbo noise
    Jan 2008
    Paisley
    The aircon compressor on mine was working ok, ie no loss of cool air just a noisy bearing. To replace is fairly straight forward, access is good once the bumper is removed. Before removing though the air con system needs to be evacuated as its under pressure, and once replaced will have to be re-filled with refrigerant. A good aircon specialist can do this as well as many fast fit places like Kwik-fit etc.
    Sleaford
    Quote Originally Posted by mattv6diesel View Post
    No its increases and decreases with engine revs, whats your thoughts ?
    Karl B
    having the same problem atm aswell mate, though on mine is the 120 and its very loud wine sounds almost like siren, took it to a local garage and their adement that its the bearing in the turbo, not too sure as the turbo still spools up and operates fine, taking it to a vaux dealer tomorrow to get it sorted, still under warranty thankfully
    Redditch
    I have this too so would be interested to hear what the outcome is, my mechanic heard it and said its a bearing but he hasn't had a look yet
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    I have a whiney noise on mine as well especially when I put my foot down.
    The noise is my girlfriend complaining
    Sorry, I couldn't resist.....
    Regular Member Exclusive BV's Avatar
    West Midlands
    I had a similar noise once but not on a cdti.
    Turned out to be the alternator on the way out.
  1. whining noise
    By Swedge in forum Engine & Drivetrain
    Last Post: 21st November 2012, 23:23
  2. CDTi 150 Whining noise
    By daveb1971 in forum Engine & Drivetrain
    Last Post: 21st October 2010, 21:22
  3. whining noise (HELP)!!!!
    By wilsons 1.8sxi in forum Engine & Drivetrain
    Last Post: 20th March 2009, 09:03
  4. Whining Noise
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2008, 09:08
  5. Whining Noise
    By v6boy in forum Engine & Drivetrain
    Last Post: 13th May 2007, 01:13
