Results 1 to 10 of 13
Thread: Pipercross or K&N?
    Liverpool
    Default Pipercross or K&N?
    after taking off my cone filter and putting my box back on, i want to get a high flow panel filter, but which is best? pipercross or K&N?
    Regular Member george1987's Avatar
    Nov 2009
    Plymouth/Southampton
    I have a K&N panel filter and felt the difference with it in. I think it's the most popular one.
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    When I got my car new i ordered a pipercross for it, but after some advice from a guy who had done several tests with airflow etc on the veccy (Karl) It was soon replaced with a K&N..
    Liverpool
    cheers lads, K&N it is
    EVERYWHERE
    High flow filters will only make a difference when a diesel engine is reaching its full load limit (where it's beginning to chuck out black smoke). At that point more air would be a good thing, but even then the difference from a high flow filter is negligible. Running without a filter (not recommended) won't make much difference to how a diesel engine performs either.
    Unlike petrol engines, diesel engines only require additional fuel to improve performance (hence tuning boxes). A petrol engine requires it's overall breathing to be improved, either by boosting the turbo (if it has one) or by modding things like exhausts, cams and valves etc.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    K&n all the way I have always used them in the past and I am getting one for my vectra too. But I have also used green cotton filters too which are also good but more expensive
    Regular Member mini tony's Avatar
    Oct 2009
    stoke-on-trent
    k&n mate all the way have fitted all sorts of filtters over the years on all sorts of cars . and all states of tune from standard to full race the k&n always give the best return
    Regular Member Graeme01's Avatar
    Aug 2009
    wirral
    Quote Originally Posted by diesel dog View Post
    Y do they turn the boost up then when you get it mapped if you only need fuel?
    Dunstable
    K&N mate
    Regular Member POAH's Avatar
    Glasgow
    pipercross - K&N clog up significantly quicker (in fact a clogged K&N flows less than a paper element) and need cleaned every 3-5kmiles and re-oiled. the oil will damage the AFM if it leaks through. pipercross will get dirty eventually but it takes longer. cheapest option is to just change the paper element a so called performance air filter won't do squat for a TDi.
  1. Pipercross or K&n
    By nelly452 in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2011, 08:00
  2. pipercross or k&n
    Last Post: 24th August 2011, 17:28
  3. Pipercross or K&N
    By arkhan78 in forum Tuning
    Last Post: 11th July 2011, 18:27
  4. K&N or PIPERCROSS???
    By dan22 in forum Petrol Engine related
    Last Post: 15th April 2008, 20:15
