Thread: P1112 fault code
    Full Member lizard's Avatar
    Oct 2006
    southampton
    14 Post(s)
    Default P1112 fault code
    P1112 Intake Air Temperature Circuit Intermittent Low
    Any idea what could be causing this fault to appear periodically
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    broken/corroded wire near the senor has happened before
    Oct 2006
    southampton
    14 Post(s)
    Any idea or any pictures of where I should be looking Matt.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    no sorry not got that engine. its the only sensor on the intake pipe either on its own or as built in to the airflow meter
    Oct 2006
    southampton
    14 Post(s)
    Cheers Matt, much appreciated
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    no probs
  1. finally found a solution to the P1112 fault code :-)
    By Casper85 in forum Engine & Drivetrain
    Last Post: 7th December 2012, 14:00
  2. P1112 code finally sorted??
    Last Post: 13th September 2012, 22:43
  3. confusing P1112 fault code
    Last Post: 14th August 2012, 17:10
  4. Fault Code P1112
    Last Post: 6th August 2012, 11:12
  5. Hi CO and Swirl flap code P1112
    By silflex9 in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 11:44
p1112 fault code vauxhall
FAULT CODE P1112
