Thanks Thanks:  2
Likes Likes:  2
Page 10 of 10 FirstFirst ... 8910
Results 91 to 95 of 95
Thread: How to fix that ANNOYING CRUISE CONTROL PROBLEM
  1. #91
    Sep 2010
    Quote Originally Posted by montyfert View Post
    tried this but didn't solve the problem ,its the other end of the stalk that's my problem if i lightly hold the stalk towards the dash the cruise control stays on but within seconds of letting go it turns off so it must be where the stalk plugs in. will have to take the cowl around the steering wheel off and have a look.
    same as both my vecs mate... problem isn't the stalk itself but the connection in the column. When the CC knocks itself off (no rudies) and you find decides it doesn't want to re-engage, wiggle the stalk and it works... wondering if the constant indicating has widened the connection gap thus rendering the CC to lose connection?
    Let me know what you find when you strip the cowling
  2. #92
    Apr 2014
    sheffield
    Vehicle : Vectra c
    Trim : Life
    Engine : 1.8
    Can anyone help me,
    My cruise control has stopped working all together doesn't even activate, nothing at all happens at all when i press the button not even the lights come on. Done the pedal test it comes up with open circuit fault on cc computer and a brake light switch fault, however, there are no error codes stored when connecting to laptop diag program. No play in clutch, followed this how 2 to clean stalk contacts, still no luck.
  3. #93
    Mar 2013
    Hants
    Engine : 1.9 150
    Year : 06
    Watching with interest, same problem with mine, code reads (switch cruise control circuit open or high voltage). Possible CIM issue?
  4. #94
    Oct 2007
    estonia
    Hi everyone. My problem was that the cruise control did not engage every time I pressed the SET. Often cruis disengaged without any reason. Also cruise disengaged when I touched the cruise stalk.
    Here is what I did and for 2 month on 2 Vectra it has worked fine.
    Need to remove CIM from car and open it up. Then:
  5. Thanks Woody, GSiFan thanked for this post
    Likes Woody, pattz123 liked this post
  6. #95
    Regular Member Rhodie's Avatar
    Oct 2014
    Horbury, W Yorkshire
    Engine : 1.9
    Mileage : 75000
    My cruise control not worked properly for over a year and about that time thinking it was the stalk I bought another one from a scrappy, but that had the same fault, so assumed it was the CIM and not the stalk. Well on Sat with the rubbish weather I decided to have a go at cleaning them both using the method on page one of this thread. Took my original apart and it was covered in the white gunk. Cleaned it all up and was quite proud of myself, then whilst putting the little plunger and spring back in my missus bumped (not sure if it want on purpose, but give her benifit of the doubt) into the chair I was sitting in and like a missle the plunger and spring shot out, never to be seen again. Oh well, luckily I have another one, so I duly took that one apart and spent another ten mins cleaning that one up. The outer casing was a bit rubbish (mine was like new) so decided to swap the piston and spring over into my stalk, made sure all was well, went outside into rain and put it back into the car, took it for a test drive and guess what? Nothing, doesnt even turn on now, let alone turning on and off at will. Not sure why not, but will have another go next weekend, but I will also be paying a visit to the scappy again just in case.....
  1. Help please with my Cruise Control problem!
    By Ademusic in forum Electrical & ICE (including SatNav)
    Last Post: 28th April 2011, 13:08
  2. Cruise Control - A new problem for us??!!
    By RobW in forum Electrical & ICE (including SatNav)
    Last Post: 9th March 2011, 22:24
  3. Cruise Control Problem
    By gsi.vxr in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2010, 13:16
  4. cruise control problem
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2009, 21:37
  5. Cruise control problem
    By r.bailey63 in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2007, 20:26
vectra cruise control not working
vauxhall vectra c cruise control not working
https:www.vectra-c.comforumshowthread.php109569-How-to-fix-that-ANNOYING-CRUISE-CONTROL-PROBLEM
vauxhall astra cruise control not working
vectra c cruise control fault
vectra cruise control not working paperclip
vauxhall vectra cruise control not working
vauxhall vectra cruise control problems
vectra cruise control not working paper clip
vectra c cruise control fix
which model vectre c has cruise control
astra h cruise control not working
cruise control vectra c
vectra c cruise control problem
insignia cruise control not working
cruise control not working on vauxhall vectra
cruise control fuse vectra
vectra c cruise control stopped working
vectra c cruise control fusevectra c cruise control fuse locationvauxhall vectra 2003 cruise controll fusecruise control vectra problemvectra c tempomat
