Thanks Thanks:  2
Likes Likes:  2
Page 1 of 10 123 ... LastLast
Results 1 to 10 of 95
Thread: How to fix that ANNOYING CRUISE CONTROL PROBLEM
    Regular Member nph1's Avatar
    cheltenham/gloucestershire
    Default How to fix that ANNOYING CRUISE CONTROL PROBLEM
    HOW TO FIX THAT ANNOYING DOES IT WORK OR DOES IT NOT WORK CRUISE CONTROL ISSUE TRY THIS FIRST.
    1. get a paint brush and knife
    2. remove the control arm from the car with a sharp tug.
    3. remove the rubber part from the arm.
    4. turn upside down.
    5. useing the knife carefully remove the backing plate.
    6. remove the inside of the arm be carefull here as it is still connected with two very small clips at the outside end.
    7. pull and unclip the button end of the arm again being carefull not to lose the two small springs.
    8. using the paint brush clean the end of control in which you will see between the two silver miro chips the plastic pins that get stuck with dust and fluff.
    9. clean the springs and dust off all the other parts then put back together.
    my cruise controll is never worked so well untill i done this and wow im amazed at the diffence try it.
    Regular Member fingers66's Avatar
    Carpe Diem
    I wouldnt want to try this as I would prob be left with a useless control arm......well done to you for doing it.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by fingers66 View Post
    Thats what i thought! and there £53 + to replace if you bu**er it up!, well done though and why didnt you remove it correctly ? ie as per the 'how 2' its very easy and does'nt risk any damadge.
    with just a small tug it just simple pulls out not being funny but a 10 year old can do this it really is simply to do no wires or tec stuff to do just a matter of following this thread try it its simple
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Its done in 'seconds' the correct way and i wouldnt advise anybody to tug or snatch against the 'clip' that holds it in place, the 'how 2' shows how to do this easily.
    Regular Member KevinG's Avatar
    South Bucks
    agree, great 'how to' but dont pull the arm out, slide a paper clip up the groove and it falls out.
    Regular Member djr69uk's Avatar
    Midlands
    agree with comments. no point yanking it out and risking breaking when a paperclip releases it gently in seconds!
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Cheers I've just completed this, all working fine. Nice one Thanks.
    Quite easy just look at what your doing as instructed.
    Post
    ok point taken take out the arm as above if someone can correct the above information and put this thread into the howto section please.
    I am also pleased someone esle has tried this and it worked for you two it really is so simple to do (a child can do it )try it guys and let me know how you get on.rate this thread please
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Before attempting this ensure the spring behind the foot pedal (cannot remember which pedal!) is not borken as this is a major cause of the cruise control not working
  1. Help please with my Cruise Control problem!
    By Ademusic in forum Electrical & ICE (including SatNav)
    Last Post: 28th April 2011, 13:08
  2. Cruise Control - A new problem for us??!!
    By RobW in forum Electrical & ICE (including SatNav)
    Last Post: 9th March 2011, 22:24
  3. Cruise Control Problem
    By gsi.vxr in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2010, 13:16
  4. cruise control problem
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2009, 21:37
  5. Cruise control problem
    By r.bailey63 in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2007, 20:26
vectra c cruise control
vectra cruise control not working
vauxhall vectra c cruise control not working
https:www.vectra-c.comforumshowthread.php109569-How-to-fix-that-ANNOYING-CRUISE-CONTROL-PROBLEM
vauxhall astra cruise control not working
vectra c cruise control fault
vectra cruise control not working paperclip
vauxhall vectra cruise control problems
cruise control vectra problem
vauxhall vectra cruise control not working
astra h cruise control not working
which model vectre c has cruise control
vectra c cruise control fix
vectra cruise control not working paper clip
vectra c cruise control problemcruise control not working vectra cvectra c cruise control stopped working insignia cruise control not workingcruise control not working on vauxhall vectracruise control vectravectra c cruise control keeps turning offvectra c cruise control fuse locationcruise control vectra ccruise control fuse vectravectra c cruise control cim
