Thread: any 120 owners had fumes smell in car?
    PRESTON
    Default any 120 owners had fumes smell in car?
    hey fellow 120'ers, i have had a fumes smell in the car for a while, so far i have traced some to the egr cooler clamps being loose and exhaust escaping, i have replaced egr and new gaskets, checked all round the engine and can see no leaks, but she still has a exhaust/diesel smell comming from somewhere near the vacuum pump. any of you guys had similar and found out what it was??? ideas welcome, cheers.
    Regular Member westonprawn's Avatar
    Jul 2009
    TELFORD
    Yes mate I have the same problem anyone any ideas?? Im going to take it to get the exhaust checked out butI read some where about the 3rd injector harness being a problem but not sure ?
    Jul 2009
    TELFORD
    Also its worth mentioning it runs ok too, In the mornings how ever it runs abit lumpy/grey smokey for a couple of secs! Its not as good on fuel lately but may be unrelated??
    PRESTON
    My Veccy runs great too and to be honest the fuel consuption is brill, avg 44 mixed driving and damn near 58 mpg on the motorway. i think the third injector harness issue is related to the 150's, but not sure, maybe someone knows better. I did find that the clamps on the engine breather from the rocker cover to down the back of the engine wern't tight, its those stupid things VX use, so i changed them for jubilee clips and it does seem to smell less, going on a trip to Scotland next week, so will see how it goes.
    Jul 2009
    TELFORD
    Il check those cheers Barney, Im going the Isle of white soon and have a baby in the car so it needs to be sorted
    Jul 2009
    TELFORD
    Bump :b any other ideas what it could be anyone ?
    Jul 2009
    TELFORD
    Regular Member amir2300's Avatar
    london
    I had this issue and took it to Vauxhall. it was a seal around something. not sure what. It was under warrenty so they fixed it with no problems.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    on the front of the engine next to the turbo where the egr pipe takes it feed from there is a spring pipe and it has a seal that can leak and give the smell in the cab .,, also check the inlet manifold gasket they can leak across the top it is hard to spot so a small powerfull torch is needed to fiddle into the small areas of the manifold .....
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Not limited to the 120's but a lot of Vec's are having flexible exhaust coupling failures underneath the car.
    Have a look where the downpipes end and check around the flexible mesh for soot, as this also causes fumes in the car.
  1. smell of exhaust fumes
    By murfcitygent in forum Engine & Drivetrain
    Last Post: 18th October 2016, 18:59
  2. DPF/CAT - Strong Fumes Smell inside cabing - CDTI 150
    By Vaux-Man-G in forum Diesel Engine related
    Last Post: 1st April 2012, 17:47
  3. Fumes
    By stevie16v in forum Engine & Drivetrain
    Last Post: 19th September 2011, 21:08
  4. Fumes smell in the cabin
    By Northy in forum Engine & Drivetrain
    Last Post: 17th January 2010, 19:59
  5. Fumes In The Cab - Help!
    By MRLUBBERLUBBER in forum Vectra C / Signum Car Chat
    Last Post: 25th October 2008, 19:27
vectra c 120 smell fumes in car
