Thread: Central door locking problem
    Nov 2009
    newcastle upon tyne
    Default Central door locking problem
    Just wondering if anybody else has had this porblem before.....Basically either when locked or unlocked when i press the key fob it doesnt work,nothing at all ive tryd a new battery and it has been to vx but as this is an intermitent fault they coudnt find it...I must say it only happens maybe once or twice a month but iam worried it might get worse.I do know that by putting the key in the ignition it resets the system thus the key fob working.
    Regular Member jim skeen's Avatar
    kelso scotland
    Default same as
    Opened car today to bore holes for reversing sensors: no prob. Went too relock the car, press-press zilch. Changed battery, still the same.
    Am a tad worried as I can't secure my car. Where i live, people lock their dustbins. Anybody got a clue??
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    Quote Originally Posted by jim skeen View Post
    try to reset start car stop and close all doors then press
    Regular Member Innes's Avatar
    Plymouth
    You can lock the car via the driver side door with the key. This will lock the whole car and arm the imboliser and alarm.
    11 Post(s)
    Quote Originally Posted by Innes View Post
    Not on a 2006 onwards Vectra it won't (and possibly slightly earlier ones too)
    All it will do is lock the drivers door. To lock all the doors you have to reach in through the passenger door and press the lock button on the door panel of switches, then close up the passenger door you reached in through. Note:- the alarm won't be armed.
    ps, the locking / unlocking of the doors doesn't arm / disarm the immobiliser. That works via a transponder chip inside the key. A wrong or missing chip and the ignition won't allow the car to start.
    Plymouth
    On my 2002 vectra the drivers door does all of the central locking. That's strange the Vauxhall would change that. When my drivers side door lock malfunctioned (it wouldn't tell the ECU the door was actually shut) I had to do the following to secure the car.
    http://www.vectra-c.com/forum/showthread.php?t=107466
    I dint know if this helps with the above situation but it's the only way I have seen how ti secure the car when the locks are playing up.
  1. Central locking wont lock door
    By jonathon wycherley in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2011, 21:44
  2. Central locking problem, Drivers door
    By Big Si in forum Electrical & ICE (including SatNav)
    Last Post: 30th May 2010, 09:30
  3. One door doesnt lock on central locking
    By Chippie19 in forum Vectra C / Signum Troubleshooting
    Last Post: 21st November 2009, 00:27
  4. passenger door/central locking....
    By wbandy in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2007, 20:19
Vectra c central door locking
vectra central locking problems
