Results 1 to 10 of 13
Thread: Oil Filter location and Fuel Filter
    Jun 2006
    Newcastle
    Default Oil Filter location and Fuel Filter
    Does anyone know where the oil filter is on the Veccy C 1.9CTI (120Bhp)??
    I cant find it anywhere and the tinterweb doesnt know either!
    And what is best practice for replacement of the fuel filter
    Help!
    Regular Member Harry's Avatar
    Uxbridge, London
    look underneath! that's where mine was, but mine's not a 1.9.
    Quote Originally Posted by trickydickySRI
    Help!
    oil filter and drain are locted on the rear of the engine just above the ehaust pipe and drive shaft, comes out of the block at a slight angle..beware if you're underneath it thou,, there is a small stub tube coming out of the side of the housing and oill will drain from it when you undo the filter (32mm socket on the black end housing.)..Beware the sump bolt as well, they're soft and far too easy to round off..13mm socket..
    all located through the drop down flap in the undersheild at the rear of the sheild,(4 x phillips dzus fastners)
    The fuel filter is a drain only annually and a replacement bi - annually..
    remove clip-in lines, unscrew top housing collar and withdraw, change element and re-fit top housing and lines...turn ignition to get the dash lights on and let it sit there for about 30 seconds, this will prime and bleed the filter..start engine and it should run with no airlocks in the system..
    As per your other thread a few weeks ago, I posted up a PDF all about changing the fuel filter.
    Mileage : 000
    Is there supposed to be a plastic tray like cover under the engine bay on the 3.2V6 engine as mine does, not have one, maybe they never fitted one from new, any one with a 3.3V6 have you got one under your engine....
    Uxbridge, London
    Quote Originally Posted by Gsi3.2
    this is actually useless unless the car is on a ramp. i had to remove the entire shield, around 8 or 9 torx screws, pain in the back side!
    Quote Originally Posted by ed taylor
    nope.. none were ever fitted to the 3.2 Ed..they were fitted to the diesel to get them through the 'drive-by' noise regulations, similarly they have an acoustic top cover as well to help deaden noise..
    whereas the petrols, not having so much 'Knock' as the diesels don't need one.
    Here's the procedure for removing the oil filter on a 1.9 120. You're gonna love it - it's a beaut!! It involves removing a wheel and disconnecting part of the steering knuckle!!!!
    thats the one to remove the entire filter housing D ..i.e. the cast jobbie the filter sits in..
    you trying to scare the poor ****** to death?? drain coolant to change the oil ..
    Oh bu**er!!! You're right. That'll teach me to do it quickly!! I'll look for the right one now!!
  1. fuel filter location,
    By headscratcher in forum Vectra C / Signum Troubleshooting
    Last Post: 16th January 2012, 22:53
  2. help please,fuel filter location
    By bigbrox in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2010, 15:28
  3. Location of fuel filter housing 1.9 CDTi
    By bennettboy in forum Engine & Drivetrain
    Last Post: 1st October 2008, 23:15
  4. Fuel filter Location
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd June 2008, 18:54
  5. oil filter location
    By Darryl2.2DTI in forum Engine & Drivetrain
    Last Post: 28th October 2007, 19:32
vauxhall vectra 1.9 cdti oil filter location
2007 vauxhall vectra 1.9 cdti oil filter location
2005 vectra v6 3.2 oil filter location
2005 vectra 3.2 oil filter
vauxhall vectra fuel filter location
cannot find oil filter on vauxhall vectra 2008
change oil filter vectra c v6 3.2
