Thread: intercooler problem
    south wales
    Default intercooler problem
    hi all regarding one of my last threads (whoosing noise) i have now found the culprit see the picture, thing is see the cooler has turned from square in shape to a big bow on the bottom obviosly there has been a lot of pressure build up to expand the cores and actually rip the grill pieces off the core
    anyone know how this pressure build up has occured?
    May 2008
    Lancashire
    Dang. Mine 1.9CDTi 120 has just done the same too. Was coughing a bit at 2000rpm at steady throttle, but seemed OK (ish) whilst accelerating. Maybe a bit sluggish. Just discovered mine has a goosed intercooler. Anyone know how much a new intercooler is from VX?
    Chris
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Hi boys, just done mine as i had exactly the same fault. £188 from stealers. Fitted it myself as local garage wanted £130 to fit. It's fairly easy, hardest part is getting the front end high enough to slide the intercooler out. if you need any help/ info, just drop me a PM.
    May 2008
    Lancashire
    Yeah. £188 from stealers and a pal has offered to fit it for £30. Not worth getting my hands dirty. Happy days.
    Just hope the DPF has not got clogged up. The last few months have only done short journeys... 4 miles each way. Hopefully have it fixed for Friday and then I'll give it a godd motorwya do on Saturday to blow off the cobwebs.
    Out of curiosity, are there any warning lights or anything other signs that suggest the DPF is goosed?
    Cheers,
    Chris
  1. 2.0T intercooler problem
    By mann3210 in forum Vectra C / Signum Car Chat
    Last Post: 7th July 2011, 14:32
  2. Standard intercooler v front mount intercooler
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 29th June 2011, 09:58
  3. vec c dti, intercooler how to anywhere
    By OPELcambo in forum Vectra C / Signum Car Chat
    Last Post: 21st September 2010, 09:06
  4. Rad or Intercooler?
    By si_hoss in forum Engine & Drivetrain
    Last Post: 28th June 2010, 12:35
  5. 1.9CDTi Intercooler problem
    By Vectra Meldrew in forum Engine & Drivetrain
    Last Post: 29th March 2010, 15:59
vectra cdti intercooler problems
vectra intercooler problems
vectra 1.9 cdti intercooler failure
