Results 1 to 3 of 3
Thread: Air con comp....
    Regular Member axelf's Avatar
    chester le street
    Default Air con comp....
    How can you tell if this is starting to break????....When i switch it on it gets cold inside the car, but of a musty type smell....but when i drive there is a sort of high pitched noise outside......The belt is not slipping, it only happens when the car is moving with aircon on.....Switch it off and the noise go away....or stop the car with it running and the noise is gone....only when pressing the accelerator.....Is it the compressor on its way out????
    Regular Member signum junkie's Avatar
    Edinburgh
    Musty smell is just the system needing cleaned. Just look on line for cleaner or try local factors. I don't think the noise is related but I am sure someone will correct me if I am wrong.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Might be a bearing dying... or might just need a new aux belt and tensioner. If you can get to the belt, try giving it a 'push' - there shouldn't be be that much deflection in a good condition belt/tensioner. If that seems decent, you may want to slip the belt off and give all the pulleys you can a 'rattle' - somewhat more involved job though depending on your engine.
  1. trip comp
    By daddy07 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2010, 21:03
  2. comp advice..
    By Dwabo in forum The 'Off Topic' room
    Last Post: 3rd May 2009, 20:13
  3. Comp boffins - HELP!!!
    By mc_orion in forum General Chat
    Last Post: 29th February 2008, 22:51
  4. Spot the Vec comp.
    By Inspektor in forum Comedy & Humour
    Last Post: 22nd July 2006, 09:55
  5. cd30 - trip comp = HELP
    By installer in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2005, 21:16
