hi all
just woundering if anyone has put the above mod to there veccys and would it worth it.
thanks clembo
hi all
thanks clembo
Wot car do u have??
hi Marcosuk have just bought an 2.2 sri non direct(petrol). on 53 plate
There was some gsi 314mm brakes (full kit i think) for sale on ere a wee while ago... Might still be forsale
thanks will check that.
Being a 2.2 you'll have 285's front 278's rear
For the fronts you can have 302's (fitted to 2.0 turbos and early v6's)
314's (later V6's)
345's (VXR's)
For the back you can go up to 292's (available on all of the above)
You'll need calipers and carriers (as well as discs and pads) to upgrade
I have the 314mm upgrade front and 292mm rear and have to say i'm well impressed with the braking over standard and would recommend it to anyone who wants improved braking which is clearly noticable.
@ chrisk did you do the calipers n carriers aswell .
i did the 302mm up grade from a 2.0t and the difference is amazing only trouble is all the brake dust now lol
