Results 1 to 10 of 16
Thread: faulty parking sensors.
    doncaster
    Default faulty parking sensors.
    hi, for some reason may parking sensors have just stopped working, the light comes on, on start up, and when i pick reverse gear, the light also comes on to suggest that they are working, but theres no beeps when i go near a wall etc. any ideas..
    adam...
    doncaster
    as a quick follow up, wen working normally do the sensors turn them selves off once you are on the move. once i come to the end of a journey and park up, they are off, unless i have to reverse, and there is a beep as if they are turned on again?? what does the button on the dash do? activate or de-activate the sensors? and help appreciated..
    regards
    adam.
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    If the light is on on the dash that tells you it has a fault..
    Possibly just one of the plugs has come away from the sensor mate, worth a quick check...
    PRESTON
    hey amob, i am assuming theses are rear sensors and are either factory fitted or genuine accessory sensors. if so they have a small speaker to make the beep sound, on mine, Estate, its located in the left hand rear quarter trim. According to the previous service history it had this replaced at some time in the past, so maybe thats whats packed up on yours, as the light in the button on yours is showing them working.
    With the ignition switched on, the front and
    rear parking distance sensors are
    automatically activated when reverse gear
    is engaged.
    The parking distance sensors can also be
    activated at speeds of less than 15 mph
    (25 km/h) by pressing the button on
    the instrument panel.
    An illuminated LED and an acoustic signal
    indicate that it is ready for operation.
    Nov 2007
    weymouth, dorset
    Quote Originally Posted by barney490 View Post
    is engaged.
    You also get a failure light on on the dash when you select reverse if there is a fault with the system.
    PRESTON
    your right alan,
    the symbol on the dash is the letter P and a triangle, it illuminates yellow, indicating a fault in system.
    doncaster
    Quote Originally Posted by Penfold101 View Post
    as i kno nothing about cars mate, how would i do this??
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    look under the bumpers for the sensors and check the plugs
    doncaster
    your right alan,
    i am getting this as well so there is obviously an itermittent fault, however they strangely worked today. wot is the cheapest option for trying to get them fixed? they r factory standard sensors..
  1. Parking sensors
    By FIL 4822 in forum Insignia car chat
    Last Post: 29th December 2012, 13:12
  2. A/M parking sensors
    By Derek Mc in forum Electrical & ICE (including SatNav)
    Last Post: 15th July 2010, 15:15
  3. parking sensors
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 17th June 2010, 09:09
  4. Parking Sensors
    By gallag in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2010, 21:49
  5. Parking Sensors
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2008, 00:40
