Thread: Ncdc 2015
    Full Member Signum Dek's Avatar
    South Yorkshire
    Default Ncdc 2015
    Having jusy aquired a NCDC 2015, what options have I got screen wise and what would I get plugging it into the normal GID thats already there.
    Thanks Dek
    Half Leather Interior - Spax SS Springs - Bilstein B4's - K&N Filter/Airbox Mod - GSI Intake - Twin Chrome Tipped BackBox - Richbrook Door Pins - Irmy Alu Top Grill - Irmy Roof Spoiler - Irmy Pillar Trims - Stainless Sill Plates - Heated Washer Jets - 50w 6000k HIDs - Moulded Mud Guards - 18" VXR Replicas - Travel Assistant - CID & NCDC 2015 - Electric Folding Mirrors - Irmy Mirror Covers - Chrome Handles
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    well you need a GID thats ready for Satnav, or a CID.
    You wont get anything.. if you plug it in.. (only if you are unlucky to ruin your current screen).
    South Yorkshire
    Have you got any part no's Ken, especially for the CID.
    Thanks Dek
    Engine : 2.2 Direct
    Sorry i dont.. as they are very expencive at the dealers...
    South Yorkshire
    Having just bought a CID complete with its matching paired NCDC 2013, along with all codes for the original car, can I wire these in then divorce them, so as I can code the screen into my NCDC2015.
    Is the NCDC a direct replacement for the CCR 2006, or will I need a different cage.
    Engine : 2.2 Direct
    yes you can. The cage should be the same. Why not decode the ncde at the same time ?. He the 2013 i might could use as mine is broken
    South Yorkshire
    Just managed to get the CID and NCDC2013 fitted, everything seems to be working ok, can't test the sat nav yet as I haven't fitted the ariel yet. Then I went to unpair the two, using Vaux.com the CID reported back fine, but the NCDC unit's reporting back is sketchy, sometimes it communicates other times it just keeps trying to connect, but dosen't manage it, when it does communicate it sometimes says its security coded, other times it says its in transit mode, and it even flash's between the two then looses comms, anybody no whats going on.
    Could any one thats managed to unpair and pair new units together with vaux.com or op.com let me know the procedure, do I have to go through all the different ECU's and unprogram the CID from them on the can-bus circuit before unpairing the NCDC unit.
    And one last question, should the BC controls on the stalk still work, I can operate the BC through the radio itself or from the steering wheel controls, but the stalk seems dead.
    Thanks Dek
    Engine : 2.2 Direct
    the BC is controlled via the radio and steeringwheel controls.. not the wiperstalk, when using a NCDC and screen.
    milton keynes
    Quote Originally Posted by kenp View Post
    This is true Ken in the main, but my old NCDC2013 BC could also be controlled by the wiper stalk , my current one cant.
    Engine : 2.2 Direct
    hummm mine never been abel to be controlled via the wiperstalk what setting have i missed?
  1. Ncdc 2015 Broke
    By hardin in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2012, 21:43
  2. Ncdc 2015
    Last Post: 16th April 2011, 06:33
  3. NCDC 2015 Front Panel
    By Signum Dek in forum Electrical & ICE (including SatNav)
    Last Post: 24th July 2010, 10:02
  4. Ncdc 2015 - cid & tpms
    By stoneshed in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2009, 12:01
  5. NCDC 2015 Sat Nat Question
    By m300raj in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2009, 21:40
