Thread: engine rattle
    leicester
    Default engine rattle
    hi all got an 04 vectra v6 diesel manual it it has got an engine rattle sounds like a tappet rattle but its only two or three of them on tha back bank i think. took it to vauxhall and they recon its the injectors but wernt sure and wanted to strip it down further so i thought that i would ask you guys first then maybe do it myself any ideas
    Also do they have hydraulic liffters or are do they have shims? many thanks in advance
    Regular Member DaveW555's Avatar
    Cannock
    If the injectors were knocking that bad you should be using fuel like its going out of fashion. did vx give you the figures from the injectors when they plugged it in? If not go back and ask them to either give you the print out or read the injectors again. If the injected quantity figures are greater than +3 then you have an injector fault. this test should be done on a warm engine at tickover. as for the tappets they are adjustable and should be as follows: Inlet - 0.35-0.45 mm (cold) Exhaust - 0.4mm (cold).
    Hope this helps matey.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Try some fuel/injector cleaner first!, bearing in mind if its running ok apart from your estimated 'noise' then its likely to be something minor and i would try the above first!.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    most izuzu engines are shimmed so not sure
  1. Engine rattle
    By chillin_man in forum Engine & Drivetrain
    Last Post: 1st November 2013, 09:56
  2. Engine cover rattle and engine cough
    By Hursty103 in forum Engine & Drivetrain
    Last Post: 15th May 2012, 12:22
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. engine rattle
    By paul wingnut in forum Engine & Drivetrain
    Last Post: 11th July 2009, 13:42
  5. Rattle from engine bay
    By kenny22 in forum Engine & Drivetrain
    Last Post: 27th July 2008, 19:52
