Thread: A Vectra problem
    Jan 2010
    Ipswich
    Default A Vectra problem
    Hi Everyone,
    I have a 53 reg Vectra 2.2 direct automatic (66k) that has an intermittant problem. Around town, which is where I do most driving, it is fine. However on a faster road it sometimes develops a problem. If you accelerate fast (kick down) it gets to about 50mph and the engine seems to run really badly and the car won't accelerate. This sems to last for the rest of the journey. If you accelerate more gradually, you don't get the problem and can get to 70 easily. When this happens it activates one of the warnings (the one with the spanner), which goes when you restart the engine. Yesterday it activated the one that looks like an engine. This hasn't disappeared yet. I intend to get my mechanic to look into this problem. Does anybody have any suggestions/
    Thanks,
    Robert
    Regular Member Sambor's Avatar
    Elgin
    My is with manual gearbox,so I am not sure if that can be some problem with your automatic gearbox.Can be also fuel regulato or Siemens fuel pamp.
    http://www.vectra-c.com/forum/showthread.php?t=107803
    http://www.vectra-c.com/forum/showthread.php?t=88701
    Do you talking about read small engin?If yes,it it emission warning light.My VX doesnt like petrol from Shell gas station.Happend twice when I took fuel from Shell.After secend time when emission light came on I when to BP and emission light has gone.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by RobertsVectra View Post
    Hi Everyone,
    Thanks,
    Robert
    I notice you have a direct 2.2 mate. It might be worth getting the codes read, it could be the start of the fuel pump/ reg fault. Although im not familiar with the Auto set up and what problems that can cause. If you hadn't said it was an auto I would go straight for the pump, and TBH its still probably your best bet, but getting the codes read is a must IMO.
    Elgin
    Few weeks ago I called VX Customer Service and adviser told me that I have recall for High Fuel Presure Regulator,and my VX Dealer had change it for free.You can also check if Your car has it!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    The orange engine light is the emissions so seems there is a mixture problem I would say. There is an out of tolerance in the emissions levels which trips this light - either over/underfueling.
    Hope it is something stupid.
    Gazza4
    Elgin
    We should have hope!One of my friends had problem with fuel pump like some of guys having 2.2 Direct engins.Opel told him that he has to change High Presure Fuel pump.He didn,t buy a new one.Just he took it out and find the problem.Inside the fuel pump are 3 membranes.One of them was broken.He bought a used one and change broken one for a good one and problem disappeared.The used one cost him about £40.It's big deferent pay £40 instead of £340!
    Jan 2010
    Ipswich
    Thanks for the help so far. I have booked it in for Vauxhall to check whether the recall for the High Fuel Pressure Regulator has been applied. They have no record of it having been done. I hope that fixes it.
    Robert
    Jan 2010
    Ipswich
    Hi Everyone,
    Vauxhall said that the pressure regulator had been changed recently, so it was not eligible for the recall. As I did not have an invoice, I could not say whether it was within warranty, so I had to pay for a new pressure regulator. They fitted a new one. That didn't fix the problem. It needed a new pump as well. It is supposed to be fixed now. I will wait and see. The warranty I got when I bought the car didn't cover either part, so I had a bill of over £650. Ouch.
    The somewhat poorer, Robert
    Full Member gibbon7000's Avatar
    lincs
    Exact same problems of my old mans 2.2 direct auto signum. His was only 3 yrs old and had only done 23k turned out it was the dreaded high pressure fuel pump.
    My other car. 1972 1641cc slammed beetle. On the road finally!!
  1. Vectra wiper problem - any advice appreciated - Vectra C
    By newbreed in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2011, 20:57
  2. Vectra 1.8 LS, big problem?
    By Mattyreid9 in forum Engine & Drivetrain
    Last Post: 5th October 2010, 12:28
  3. air con problem vectra c
    By stevenrwaller in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2010, 10:03
  4. vectra c problem help
    By beemerboy31 in forum Vectra C / Signum Troubleshooting
    Last Post: 29th January 2009, 23:39
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
how to use the kickdown on a 2.2 vauxhall vectra c site:www.vectra-c.com
