Thread: Mpg question and fuel gauge
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Exclamation Mpg question and fuel gauge
    Hi all I have a vectra estate all the mods are listed in my signature and engine etc. I have a new egr plus new flywheel clutch thermostat and inlet manifold along with. New alternator
    I have a caterman box fitted and I was doing mixed
    driving mostly motorway speeds with some heavy acceleation and over taking combined with 100miles of a roads I have done 336mile and used neArly 3/4 of a tank with a range of 200miles left but I won't get that out of this tank
    air con has not been on and windows have been up the car runs fine and pills like a train I have a fault code stored with the car and spanner light on ignition which I will read tonite and post up the code
    why is my miles to a tank not good and also the fuel gauge goes deon very fast even when driving gently any help really appreciated
    kings lynn, norfolk
    i seen the fault code and it was p0002-52 rail pressure control range/performance
    i take it the tuning box is causing this there is no driveability problems with the car and the spanner light never comes on when driving it only happens now and then when i turn ignition on the light stays on untill i start the car thats it once reset it will be weeks till it comes back
    any ideas guys also about the mpg issue too cheers
    kings lynn, norfolk
    Bump
    Someone must know about this any one else had problems with mpg on there estates when all is well and how many miles do you get on a full tank with half motorway and half town driving
    car is perfect running order no faults and has following mods in signature
    will the dpf cause less mpg than a hatch vectra
    I keep comparing it to my tdci mondeo I had which could get 700miles on a tank and it was a estate with a decat pipe
    Regular Member DaveW555's Avatar
    Cannock
    I'd be happy with that kind of mileage out of mine tbh and mine is a CDTi 120. It does about 450 - 500 on a full tank and my mrs drives like a vicar. Its still on standard mapping with only the air box mod done so far.
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    I mentioned the figures for an estate in a thread this morning:
    http://www.vectra-c.com/forum/showthread.php?t=109547
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    I've recently had my DPF removed and the read-out shows i'm doing around 60mpg (although it's not greatly accurate, so might be closer to mid 50's). So accordingto the read-out, the car will do over 700 miles to the tank.
  1. Fuel Gauge
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2013, 09:40
  2. Fuel Gauge
    By don23 in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2011, 23:09
  3. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  4. Fuel gauge
    By lob1954 in forum Electrical & ICE (including SatNav)
    Last Post: 18th April 2009, 13:03
  5. Replies: 2
    Last Post: 15th September 2008, 23:18
