Results 1 to 10 of 14
Thread: steamy windows
    slough
    confused steamy windows
    hi guys as soon as i get the slightest bit of rain on my car the windows steam up it only does it when its raining im not using the recycle button is this normal for vectra c`s i never had this on any other cars i had and other vectras i see are not steamed up
    Glasgow
    Open up the flap on the near side of the car underneath the wipers theres a big drain in there which is probably full of junk. Thoroughly clean that out and replace your pollen filter and job done
    Regular Member yessof's Avatar
    Jan 2008
    west yorkshire
    Hi could be the pollen filter needs replacing, cheap and easy to do
    Regular Member Liam1984's Avatar
    Sheffield
    As above m8 used to do it on the vec b aswel
    Liam
    Regular Member Exclusive BV's Avatar
    West Midlands
    Whatever happens, m8 dont resort to using 'Rain x anti fog'
    That stuff is garbage, it made my old car worse
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I was getting that on both previous cars, if the above doesn't work try giving it a couple of good cleans with something like Autoglym glass cleaner inside. First time on mine improved it, second cured it.
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Are the carpets dry....???? or damp due to the blocked drain hole mentioned above.....
    Admin plasma's Avatar
    On the Forum
    321 Post(s)
    Engine : 150
    Mileage : 74000
    You let Tina Turner loose in yer car?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    london
    the inside of the windows and windshields are dirty, maybe from cigrette smoke , etc. if you clean all the windows from the inside until squeaky clean (i use window cleaner and kitchen towel)and then change the pollen filter for a new one, that should stop the inside steaming up.
    Regular Member kristian's Avatar
    nottingham
    Year : 2002
    Mileage : 175000
    just seams to be my boot window that steames up any ideas
  1. steamy windows
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2012, 08:16
  2. Instant steamy windows
    By gsi3.2Daveyg in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2009, 14:06
  3. Steamy Windows
    By ballmonkey in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2008, 20:51
  4. Steamy windows
    By Baldy in forum Bodywork & Interior
    Last Post: 12th January 2008, 20:35
  5. Steamy windows!
    By scott_150cdtisri in forum Bodywork & Interior
    Last Post: 21st December 2006, 20:13
