Thread: can these be changed>
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default can these be changed>
    hi all can the bulbs in the illuminated sunvisors be changed as my drivers one isnt working?
    Darlington
    Yes, i think in the handbook it explains how to remove the bulb, IIRC they are exactly the same as the ones on my old Cavalier, and you need to CAREFULLY remove the plastic lense from the front. - however i would consult your owners manaual 1st
    Darlington
    Edit, ive just had a quick look through the manual and there as far as i can see no mention about replacment -so please disregard what i said. sorry about that.
    Regular Member mileff's Avatar
    Bulgaria
    Yes, they can be changed. You need to remove the plastic lense from the front. All you need is knife You could even change the bulbs with leds These are my sunvisors
    Darlington
    Hi, they look brilliant is it easy to fit the LED's, what type of LED's did you use?, and where did you get them from?
  1. Changed my car
    By wolvesdaz in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2012, 19:48
  2. Has anything changed?
    By bbdp in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2012, 01:32
  3. CIM CHANGED NEED TECH2 in OXFORD AREA HAS ANYONE CHANGED A CIM BEFORE?
    By vectrasimonsri in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2011, 20:43
  4. how much has your car changed since you had it
    By tonyt in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2008, 15:21
  5. My Name Has Changed
    By 3.2_V6_VXR in forum General Chat
    Last Post: 18th July 2007, 04:37
