Thread: air conditioning
    london
    Default air conditioning
    can any one recommend place to get air con parts. need to get compressor, condensor, reciever dryer and possibly an expansion valve.
    Regular Member GAZWAH's Avatar
    darlington uk
    go to a scrappy.....cos its gonna cost you a fortune.....
    how come you need full setup?
    london
    regassed itand put some tracer dye in as it did not work found leak in condensor at front. compressor is also leaking behind pulley. but when its run the pressure is too high. so filter is either blocked in reciverdryer or expansion valve has gone.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I used this bunch for parts when i did my Omega. Delivered quick, everything was brand new, undamaged, well packaged and sensibly priced.
    A scrappy might be an option, but then there's also the thought of going to all the trouble to get parts from them then finding out something's knackered.
    In the long run you might be better off with all new parts - at least you then have warranty to fall back on.
    http://www.automotive-air-conditioni...cle-parts.com/
  1. Air Conditioning
    By scarydeath in forum Vectra C / Signum Troubleshooting
    Last Post: 21st April 2012, 20:32
  2. Air conditioning HELP!!!!
    By s0501291 in forum Engine & Drivetrain
    Last Post: 1st June 2009, 11:44
  3. air conditioning fan??
    By alexander08 in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2008, 15:47
  4. Air conditioning
    By cbee101 in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2008, 14:44
  5. Air conditioning
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2007, 21:32
