Thread: kangarooing at 2k rpm when warm
    norfolk
    confused kangarooing at 2k rpm when warm
    Hi our 1.9 CDTI SRI 150 2005 is kangarooing when it gets to 2000 revs, it does it more the warmer it gets. Its just had a new EGR valve fitted and new manifold gasket as a metal bar had broken off but we've still got the juddering problem, no errors are showing on the computer either! help!!!! we're due to go on a 9 hour drive next weekend!!
    Basingstoke
    Mine's doing the same. Did yours start before or after the EGR valve was changed?
    Strange thing is mine drives perfectly with the EGR valve disconnected although it's brand new. Can't fathom it out!?!
    norfolk
    It did it before we replaced the egr valve, it has got better but its still there, not sure now if its the 3rd injector, have you had yours looked at yet?
    Apr 2009
    leicester
    Mine was the same last week, i have replaced the boost sensor (£25 off ebay) and touch wood it seems to have cleared the problem.
    Basingstoke
    Managed to speak to a md mechanic and he was a bit stumped although he found a split vacuum hose and thought that might be the problem. I fixed that but still the same. Mine wasn't doing it until I changed the EGR valve (changed because I had the low power at low revs common problem which was cured but introduced the kangaroo fuel!). He also mentioned that the boost sensor is a common problem so I'll try cleaning it and see if that makes any difference. Thanks for the tip alkez100.
    PS guys, does/did yours make a 'huff huff' sound also when it kangaroos?
    norfolk
    Hi thanks alkez100 and daveymaboy, will check the boos sensor only 2 days till we go on our long drive, will also check fuel filter too
    Basingstoke
    If the boost sensor does not fix it then try disconnecting the EGR electrical plug. Mine drives perfectly like this!?!
    Basingstoke
    Cleaned the MAP sensor today. A definite improvement but still doing it very slightly so I'll replace the sensor next. Thanks for the tip alkez100.
  1. Car kangarooing Help Please!!!!
    By alsinky in forum Engine & Drivetrain
    Last Post: 21st December 2012, 14:45
  2. Warm welcome
    By Billythebubble in forum Introduce yourself.
    Last Post: 18th September 2011, 14:58
  3. to warm
    By graham a in forum The 'Off Topic' room
    Last Post: 28th June 2011, 20:33
  4. Judder/kangarooing on take off
    By rec in forum Engine & Drivetrain
    Last Post: 26th August 2010, 19:06
  5. A bit warm
    By MattW in forum The 'Off Topic' room
    Last Post: 25th July 2008, 21:12
