Thread: Aircon dial problem
    Nov 2009
    Norfolk
    Default Aircon dial problem
    My central button on my car, the one you press in to get to the aircon screen is very tempremental.
    You have to give it a bit of a shove to get the screen to come up.
    Is this a known fault?
    Is it possible to just clean it up or is it a very fiddly job?
    Car is a 3.2 Siggy Elite if this makes any difference.
    Glasgow
    Mine is exactly the same sometimes i feel as if its close to breaking when i push it in
    Ive ended up just leaving the aircon on, the fuel consumption wont take much of a hit as its such a large engine but i might try and source a cheap new control panel once the summer is out of the way.
    Regular Member Piston broke's Avatar
    Stroud
    Same problem with mine, I want to strip the unit down but first need to get it out of the dash and have no idea how it comes out. I don't want to start levering plastic off without knowing how and where it's all fixed. Haven't had my vectra long so don't know my way around it all that well yet.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I'd have a dig about for a replacement either from a scrappy or off the bay. Chances are if the switch is that worn from being wellied instead of lightly pressed, a cleanout isn't going to make a whole heap of difference.
    Regular Member firefox007's Avatar
    Zagreb
    Why cleaning would not help. a thousand times I've cleaned the remote controls for TV, which were almost dead, and after cleaning worked like new. My problem is how to dismantle it all. I know how to pull the unit out, but the dismantling worries me. I believe that the central switch, connector inside is just dusty and greasy.
    If someone has tried to solve this problem, i woud like to get some instructions.
    I doubt you will find the climate unit that works on junk yard, becouse this is problem on all vehicles with automatic climate control.
  1. Aircon problem?
    By Mads in forum Engine & Drivetrain
    Last Post: 5th September 2012, 22:58
  2. strange AIRCON problem
    By sthomson1 in forum Vectra C / Signum Troubleshooting
    Last Post: 27th February 2011, 17:42
  3. can aircon problem put eml light on?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2010, 20:39
  4. Aircon problem
    By RN37 VXL in forum Vectra C / Signum Troubleshooting
    Last Post: 24th January 2010, 05:19
  5. Vectra C 3.2 V6 Elite Aircon problem
    By Milden in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2008, 21:18
