Thread: Front door stop cracking !
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Default Front door stop cracking !
    Hi all, two work mates have got nasty cracking sounds coming from
    the front drivers door stop, this is when you open the door half way
    to were it latches in the first indent ! does any one know of a fix or a
    adjustment that can be made to stop the cracking, one m8 has wanged loads of grease in but it didn't make any difference !
    Any info would be appreciated,
    many thanks
    Kcs
    West
    Check the bolts are tight, grease it up... if that fails replace it
    Regular Member old cruiser's Avatar
    slough
    Just had this with the wife's Clio, just tigtened up the check/ door stop on both ends, greased it all up and all is good now. HTH
    Cheers Pete
    Regular Member crespo's Avatar
    Bournemouth
    had this with mine.
    i sprayed white grease inside the door where the silver metal bit goes in the middle of the door. hope that makes sense.
    its not the hinges but the middle bit.
    sorted mine anyway.
    Regular Member sri cdti's Avatar
    Apr 2009
    Winsford
    replaced mine this week mate parts about £18 from the stealers and takes about 20 mins to fit, its so nice to have a quiet door again
    Regular Member wardy's Avatar
    Chichester
    if under warranty (being an 07) take it to dealers and get the stop straps changed
    Feb 2007
    Tamworth
    Thanks for all the info lads,
    cheers
    Kcs
  1. bump stop on front struts do i put them on coilovers
    By 6009tristanb in forum Suspension, Wheels & Brakes
    Last Post: 9th July 2012, 21:41
  2. loud cracking noise when opening/closing door
    By marky2027 in forum Bodywork & Interior
    Last Post: 5th December 2011, 20:19
  3. That's an expensive door stop!
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2008, 00:16
  4. door "cracking"
    By wardy in forum Bodywork & Interior
    Last Post: 31st October 2007, 08:41
vectra c door stopper
doorstop vectra c
vectra c door stop
