Thread: Broken front electric window regulator
    Bedford
    Angry Broken front electric window regulator
    Drivers door window dropped down into the door frame today, stripped down the door to find the regulator arm had broken it's 4 spot welds onto the geared quadrant that rotates with the electric window. I say 4 spot welds but only 3 of the welds had taken, the 4th spot weld had not penetrated. Straightened the regulator and used my mig to re-attach the regulator arm to the gear quadrant. Rebuilt the door and everything now ok.
    3 hours work for a faulty weld - has this happened to anyone else - or am I just lucky !!!!
    up north
    Nope.. Happened to me a couple of days back.. Driving round with a plank of wood jammed in the mech until I find a decent piccy to look at.. Dont have a rivet gun handy to stick the mech back together.. Suprised it isn't classed as a common fault.. The mech is very poorly assembled.
    West
    Happened to me in my old Vec c, although it had already had a repair done... so replaced it £65
    Regular Member mikeeaston's Avatar
    widnes
    my window reg has just snapped on the 4 welds just wondering how many other members out there have had this problem and if i should replace or get it welded back on
    Oct 2007
    Shropshire
    Mine did that. Vx replaced it under warranty and told me I'd abused it. All I did was press the up button, how can I abuse it?
    Glasgow
    Quote Originally Posted by alanatrr View Post
    I know this is an old post but has just happened to me and does go with a bang. How does regulator come out, i have removed door card and vapour seal just trying to see how regulator comes out etc. I can see welds are broke. Do you have to remove the rivots holding it to the inner door skin?
    hopefully you will remember. thanks in advance
    May 2008
    Tyneside
    You have to drill out the pop rivets to remove the regulator so you will need a pop rivet gun to replace it. When drilling out the rivets make sure the glass is out the way so you don't smash it.
  1. Replacing drivers electric window regulator
    By Kev_A in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2013, 05:36
  2. broken electric window??
    By BiggDaddyT in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2010, 18:00
https:www.vectra-c.comforumshowthread.php109430-Broken-front-electric-window-regulator
vectra c window regulator
how can windo wainder welding
vectra window mechanism replacement
vVauxhall vectra front window regulator
vectra c window regulator replacement
vectra c window mechanism removal
how to change window regulator on vectra c vauxhall vectra window regulator 2007how to fix a vectra window regulatorvectra c window regulator how it workschanging vectra c window mecvauxhall vectra c window regulatorwindow regulator vectravectra c window regulator removalvauxhall vectra replace window regulatorvectra c window lifter repairvectra c window motorvauxhall vectra window fell in doorvectra door window controller repair vauxhall vectra c window regulator installationhow to change vauxhall vectra window regulator vauxhall vectra window regulator replacementvectra c window fell intovectra front window weld broke
