Thread: Engine cover insulation
    Regular Member old cruiser's Avatar
    slough
    Default Engine cover insulation
    Was looking at a mates car yesterday and his is the Z22YH engine whereas mine is the Z22SE ; when we took the top engine cover off I noticed his had insulation/sound deadening pad fitted to the underside of the cover itself and mine doesn't have this, should the Z22SE have it or not is the question more out of curiosity than anything? the other thing that did spring to mind with his having it fitted, is could this be contributing to fuel pump / regulator failures on the Z22YH engine due to potential lack of air flow in and around the top of the engine I wonder and these components over heating as it were?
    Cheers Pete
    Melbourne, Australia
    Direct injection engines tend to be much noisier - that's why they need additional noise deadening material over the port injected engines.
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    i got the z22yh and it doesnt have sound deadning hmmmmmmm.......
    slough
    Quote Originally Posted by stevedee3 View Post
    Good point thanks mate.
    Cheers Pete
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by old cruiser View Post
    Cheers Pete
    Hi mate
    It does not make a Differences to the noise I took mine off as I thought it was over heating after my fuel pump went and it made no more noise than it normally does.
    Its now back on the engine the insulation only covers the engine not the pump its self how ever im going to be sorting out some ducting to create more flow to the pump and reg.
    The YH Engine is alittle noisier due to the Higher compression
    slough
    Ok cheers for that mate
    Cheers Pete
  1. Engine cover rattle and engine cough
    By Hursty103 in forum Engine & Drivetrain
    Last Post: 15th May 2012, 12:22
  2. Engine cover ?
    By aps in forum Engine & Drivetrain
    Last Post: 25th August 2011, 18:40
  3. Engine Sound Insulation
    By Diesel Dude in forum Engine & Drivetrain
    Last Post: 20th January 2011, 22:51
