Results 1 to 10 of 13
Thread: clutch expectations on 1.8
    Regular Member gregj's Avatar
    Jan 2010
    belfast
    Default clutch expectations on 1.8
    Hi folks
    I have bought a second hand Vectra C Design 2006 of a dealer about 3 months ago.
    For the past 3 months, I put 3k miles on it. Meanwhile had to have power steering pump replaced, and aircon re gassed (it wasn't doing its job when it was rather hot outside).
    But another thing starts to fail, the clutch. And now, I am wondering - is this some sort of Vectra thing, that clutch fails after 35k miles ? I am pretty sure, at least on other makes, that expecting clutch to last at least 50k is not something unreasonable.
    The reason I am asking is, because dealer I bought it from, despite 12 month warranty, refuses to replace the clutch on basis that it is the 'wear and tear' thing. Obviously, a blunt lie, since they - as Vauxhall dealer - vouched for the car, by selling it to me with 'quality' promises.
    Any comments on that please ?
    (this is my first post, so please don't bash me).
    hull
    my 1.8 (54reg) has 132k on it, original clutch...
    other vec b 1.8 164k original clutch, replaced at this point due to slipping.
    Regular Member tammyman09's Avatar
    tamworth
    I have vec c 05 plate, it had 30k on it when i bought it in september 2008, the clutch packed up at around 39,000 1 week befor the warrantee ran out (august last year)...right game i had trying to get them to replace it, but with threats of taking wilnicote motors to court, they suddenly jumped into action!
    Regular Member DaveW555's Avatar
    Cannock
    If its a second hand motor from a vauxhall dealer shouldn't it be covered under network q? I'd play your face with them big time on that one matey as I'm fairly sure that the clutch IS covered on net q warranty. Double check your warranty paper work as there is absolutely no way the clutch should be goosed at that mileage, my diesel clutch was still ok at 99k only changed it coz i changed the dmf.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Would have thought that a clutch would last longer than that. What makes you think the clutch is worn out?
    I have a 2.2dti on its original clutch on 91k and i tow a caravan with it, and its still fine.
    tamworth
    Quote Originally Posted by DaveW555 View Post
    mine was a net q car and yes it is covered, so if your car is net q then it will be replaced. Wilnicote Motors dragged their feet even net q got involved with it. but all garages cant be like them!
    Regular Member yessof's Avatar
    Jan 2008
    west yorkshire
    Hi mate I've got a 06 plate 1.8 sri. My clutch started playing up at 20k. No joy with vx they will only replace them up to 17k foc. unless the clutch only judders when its cold, like first thing in the morning. Quite a common problem with the 06 plate 1.8s I'm lucky local garage replaced it for £325
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    What's the problem with your clutch? Is it juddering when the engine/gearbox is cold?
    If it is this, then it's a common fault which could have been sorted, i understand, when the car was much younger. Sounds like either it didn't materialise that early, or a previous owner didn't get it sorted.
    I didn't get my car from a VX dealer & my juddering clutch only materialised after i had it a few months. Once its all warm it doesn't judder.
    Regular Member SRimonkey's Avatar
    wednesfield
    mines playing up but think its the slave cylinder not the clutch and i`m on 75k now.....plus its just been to north wales and back(the new clutch and slave cylinder were in the boot incase tho)
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by gregj View Post
    Hi folks
    The warranty on most second hand cars covers things that break NOT things that ware out, but if you bought the car from a Vauxhall dealer then I would be having WORDS
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
