Thread: Micro Switch - electronic opening tailgate
    Regular Member Led's Avatar
    Kings Langley
    Angry Micro Switch - electronic opening tailgate
    Does anyone out there have the part no. for the micro-switch ?
    Mine has become very intermitent and it's ****** annoying.
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    i had this problem not long after i got my veccy. tried wd40 & electolube through where the button goes but didnt solve the problem. in the end i took the tailgate interior trim off, removed the microswitch, cleaned it, put it back, wiggled it about a bit & it then worked perfectly until the lock packed up a few months ago, when i got a new lock for about £30. Original microswitch is still working perfectly.
    Kings Langley
    confused
    I've stripped the back out 3 times now, removed everything, cleaned, re-lubed and re-assembled it.
    It all works well but only lasts for a few weeks before it becomes intermitent again
    The only part that is totally sealed is is the micro-switch the housing for it is snug and a good fit.
    I sent my wife to the VX stealers and according to the spares dept man - he seems to think that the micro switch isn't available by itself
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    hmmm, tricky one. i originally took mine to the local stealers & they reckoned that it was a faulty 'actuator' whatever that was and wanted £30 just for the part! After a little while & getting my hands dirty i had fixed it for £0 as stated in my 1st post.
    then, just before christmas my boot would open only very intermittently, if at all. took the lock mechanism out & tested it, but it never worked in the car, so got a new one from the stealers for the aforementioned £30, now all is well again.
    so, my point is, the problem may not be the microswitch. the lock mechanism can be bought as a single unit, without any extras & is reasonably priced in my opinion. may be false economy getting one from a breakers as that may not work properly, if at all, best get a new one.
  1. electric tailgate opening when car unlocked
    By dreams3577 in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2012, 19:17
  2. micro switch on towbar
    By brains in forum Electrical & ICE (including SatNav)
    Last Post: 27th August 2011, 22:21
  3. Rear Tailgate not Opening on vectra estate
    By si_sri in forum Bodywork & Interior
    Last Post: 28th November 2009, 21:06
  4. Estate Tailgate not opening
    By Ewormaharg in forum Troubleshooting
    Last Post: 18th October 2006, 19:51
signum boot micro switch removal
vauxhall vectra boot micro switch
vectra c tailgate close switch
vauxhall corsa rear door wont open
micro swithch for vauxhall vectra boot
https:www.vectra-c.comforumshowthread.php109348-Micro-Switch-electronic-opening-tailgate
meriva micro switch for electric boot
tailgate micro switch for astra 06
opel vectra c estate electric open back door
2006 vauxhall vectra c estate how do you remove the hatch lock mechanism
insignia estate micro switch
vectra c boot lock removal
vectra c tailgate open button
