Results 1 to 10 of 15
Thread: Code p0380, how do you find faults in glow circuit?
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    Default Code p0380, how do you find faults in glow circuit?
    Hi, got the p0380 code, which relates to the glow plug circuit, it's had new plugs, the old ones were knackered anyway, and a new control unit but the light still comes back? I can't afford to take it anywhere so does anybody know how I go about testing the system to find the fault? The glow plug light comes on like it should, Many thanks Gaz.
    Apr 2009
    stockton-on-tees
    Check to see if any of the new 1s have been snapped wen fitted easily dun
    Jan 2010
    Cornwall
    Which bit would be snapped? It's a cdti 150 not a dti if that's what you mean. Ta.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    the enigne wireing loom has rubbed where it passes near the the top of the bell houseing give the loom a tug and twist and see if it the problems is made better ,,,,
    Jan 2010
    Cornwall
    blimey. ok I will give it a try.
    Jan 2010
    Cornwall
    Examined the loom around the gearbox and gave it a tug but everything looked fine? Whereabouts will the glow plugs have snapped if thats the case?
    Jan 2010
    Cornwall
    Any help greatly appreciated
    Feb 2006
    dudley
    Quote Originally Posted by Gazza36 View Post
    give the loom a tug pull it hard away from its mounts and the bell houseing try and twist it slightly .....
    Regular Member BoroDave74's Avatar
    Attleborough
    I had same error code and had plugs and relay changed. All the suggestions received included the loom one above, checking plugs and finally replacing the temperature sensor behind the front number plate area.
    This last one resolved it for me.
    All the non-Vx mechanics admitted that with the new plugs and relay, the fault as such was not important enough to warrant spending time and money on as the use of the glow plugs isn't as vital as I'd always believed. My car started and ran fine for all the summer, autumn and winter months last year with the spanner light coming on when temperatures were between -5 and 4c; no mpg loss, passed an MOT at a stealer too, emissions fine etc.
    Changed the sensor and spanner light free for the last 5000 miles .
    The part is cheap about £11 or so, I had my mechanic fit it whilst doing something else (brake light relay) so I'm personally not exactly sure where it goes and how easy self-fit might be. hth mate
    Jan 2010
    Cornwall
    A-ha, it did have a fault code for that as well so that would make sense, Cheers.
  1. P0380 Glow Plug/Heater Circuit "A" Malfunction
    By sinless in forum Vectra C / Signum Troubleshooting
    Last Post: 9th March 2012, 21:38
  2. FAULT CODE HELP: p0380-08 glow device general error
    By merikiito in forum Engine & Drivetrain
    Last Post: 19th November 2011, 17:28
  3. P0380 - Glow Device Circuit Low Voltage
    By benwalters82 in forum Engine & Drivetrain
    Last Post: 5th March 2011, 01:13
  4. P0380 Stored Glow Plug/Heater Circuit A Malfunction
    By frag45 in forum Engine & Drivetrain
    Last Post: 5th January 2011, 13:01
vectra p0380
OPEL P0380
Vauxhall P0380
vauxhall signum 2006 po380
P0380 OPEL
vauxhall meriva po380
vauxhall opel meriva spanner light p0380
p0380
p0380 vauxhall
Corasa d p0380
p0380 vectra c
p0380 opel corsa c
opel fault code p0380-2
OPEL CORSA P0380-A
vectra sri cdti code p0380p0380-08 vauxhallpreheating light dont wanna go on opel corsa 1.7 dtip0380-08 opelvauxhall meriva 1.7 cdti p0380p0380 meriva 1.7errore p0380 opel corsa c 1.7dtip0380 vauxhall zafiraopel vectra c eroare p0380p0380 zafira b 1.9 cdtiVauxhall DTC P0380-08
