Results 1 to 10 of 11
Thread: wet passenger footwell
    argyll, scotland
    Default wet passenger footwell
    hi there i changed the interior in my facxelift vec two days ago and ive just noticed that my front and rear passenger footwell is soaking, any ideas what has happened or have i done something terrible ??
    anyone have the same problem and its a quick fix ???
    Full Member spennny's Avatar
    Blantyre
    There is a drain hole underneath the scuttle panel passenger side , lift the bonnet and you will see a rubber seal run along under your window wipers, from the passenger side lift it up and you can see a flap, open the flap and in there it may be full of leaves and stuff, clear it out and you will /should see a drain, poke something through it to clear it ,
    Regular Member Ollie's Avatar
    Jan 2010
    Towcester
    Engine : 1.9 CDTi (150)
    Mileage : 126000
    Have you checked to see if you need to fit incontinence pants to yourself and/or your passenger?
    argyll, scotland
    will try the drain plug when i get home, hopefully that will be it !!!
    thought i had ******ed something up when fitting new door cards
    cheers for the reply
    May 2008
    Derbyshire (south)
    It will possibly need a new pollen filter too, as the one in atm will be fubared & once dries, it will stink the car out too..
    Cambridgeshire
    as mentioned above, had same problem, found literally mud in the drain holes, poked it through and hosed out, depends how deep the water is/was for pollen filter change but advisable either way!!
    Regular Member old cruiser's Avatar
    slough
    Quote Originally Posted by n8sby View Post
    You didn't remove the plastic sheet (water vapour barrier) from the doors did you? as this can lead to water getting in to the footwells, however I suspect more that it's your scuttle drain holes blocked.
    Cheers Pete
    argyll, scotland
    nah didnt remove the sheet on the door card, checked the bung and its full of crap so think thats problem sorted, there was a fair bit of water in there still aswell
    cheers for the help
    May 2008
    Derbyshire (south)
    Glad you got this done, just a case of drying up the Carpet now,, i got over 2 litres out with a vax when mine was bunged up..
    argyll, scotland
    yip but itll have to wait till next week as im off on holiday tomm
  1. water in passenger footwell
    By les287 in forum Bodywork & Interior
    Last Post: 10th October 2012, 21:23
  2. wet carpets in passenger footwell
    Last Post: 7th July 2012, 13:33
  3. Wet passenger footwell
    By aaruck in forum Engine & Drivetrain
    Last Post: 2nd October 2010, 11:13
  4. Passenger footwell wet in the Vec-B, HELP!
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2010, 22:22
  5. wet passenger footwell
    By al21784 in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2007, 23:42
