Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: Oil in coolant
    Regular Member saulfreak's Avatar
    Jun 2006
    Mexico City
    Unhappy Oil in coolant
    Really bad news folks, yesterday I noticed my coolant deposit was brown, today I took it to the mechanic and after looking at the chocolate milk in the coolant the diagnostic was unclear, they said it could be the radiator or the heads joint.. they´re starting with the radiator, 5 days without the car and a hefty replacing price later we´ll know if that was the problem or they need to go ahead with the engine check, the warranty is for one year only in Mexico so no luck there, and it only has 28,400 km... I´m truly, deeply, madly sad...and broke
    Oh man - that's sad to hear!!
    Hope it's not expensive!!
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Sounds like head gasket to me
    That does sound like a possible culprit - although at only 28,000KM it's a bit alarming!!
    Another likely suspect is the oil cooler. Where is it on the 3.2 V6? I know on the B it was in the V between the two banks of cylinders. Absolute bi*ch to get to and mahoosive labour bill!
    Hertfordshire
    If it was any other engine, yeah I would say head gasket.
    But on the V6 (assuming the basic design is similar to the earlier 2.5/2.6's and I think it is) I would vote for the oil cooler at this mileage, which is as he ^^^ said.
    Jul 2006
    Mexico
    Sorry to hear that amigo....you an me know that warranty and service down in our country usually sucks....hope is nothing too serious
    Keep us informed with the outcome
    Saludos desde Coahuila.
    Iwould put my money on the oil cooler my car has had a new one at about 30,000 miles apparently they are a bit troublesome !!!!!!
    Saul...
    you got an auto or a manual gearbox.. cause you all know what i'm thinking if it's an auto..
    Why are they starting with the radiator? that won't cause the contamination..is there any present in the sump oil??.. if it is the oil cooler then we could prob guide you on how to change it yourself from over here
    Regular Member 24vElite's Avatar
    Rustington, West Sussex
    If your has an auto box it is probably the oil cooler for this. There is a known problem on the early 3.2 autos due to failure of a seal in the auto fluid cooler that is built into the bottom of the engine radiator. If it is this problem then it means a new gearbox and radiator. Get them to check this before they start messing around with leaks from cylinder heads etc.
    two at the same time eh 24Velite..
  1. Coolant
    By tubby in forum Engine & Drivetrain
    Last Post: 16th November 2012, 21:36
  2. which coolant ??
    By VecPower in forum Engine & Drivetrain
    Last Post: 30th October 2010, 18:04
  3. Coolant Top Up
    By alembicbassman in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2010, 15:54
  4. Coolant
    By Bloicy 3.2 V6 GSI in forum Engine & Drivetrain
    Last Post: 23rd August 2009, 12:19
  5. Oil in Coolant!!!!!!!!!!!
    By mipai in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2009, 14:43
