Thread: Folding Mirror Problem
    Essex
    Default Folding Mirror Problem
    The passanger side (nearside) mirror 'folding' on my Signum has stopped working.
    It started to judder when opening and closing now it doesn't work.
    I am assuming there is an issue with the motor/ worm drive.
    I took the mirror off yesterday but it wasn't obvious whats the problem.
    Does anyone know if i can run a live feed to the motor to see if it is still working, if so what pins do i need to 'short'
    Electronic adjustment of the glass still works perfectly fine so i assume its not a fault with the door module.
    Drivers side still folds on fob or door button pressing
    For information its a '53' plate Signum 3.2 V6 with memory seats and the mirrors have only ever 'unfolded' by pressing the door button and both mirrors adjust individually, if that make any differnece
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Do you use the folding bit much? as if not.. you might just need to excezice it! (spells like crap today)
    11 Post(s)
    Quote Originally Posted by stoneshed View Post
    Sounds like it had semi siezed and because you did nothing about it (ie, lubricate the mechanism) its now siezed totally.
    Have you tried oiling/greasing it at all on the pivot joints?
    Essex
    Problem solved.
    Took the back casing off and it appears when the mirror folded it nipped one of the wires and cut it.
    One crimp connector and some tape later and its all working
  1. Folding mirror conversion
    By Smudger34 in forum Electrical & ICE (including SatNav)
    Last Post: 5th November 2012, 22:01
  2. Folding Mirror Question
    By leeds vectra in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2012, 09:44
  3. Folding Mirror Cover
    By paulw563 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2010, 18:06
insignia door mirror wont fold in completely
opel insignia mirror problem
vauxhall insignia folding mirror oiling
insignia electric wing mirror sticking
opel vectra c power folding mirror failure
insignia lubrication mirrors
