Thread: A few Problems need Diagnostic
    Aug 2009
    Camberley
    Exclamation A few Problems need Diagnostic
    Hi
    I have a few issues with my vectra 06 sri 150s and need to plug into a diagnostic tool, before i buy one from ebay i was wondering if anyone near Camberley in Surrey has one i could plug in quickly for a read out of error codes.
    I would be very gratefull if anyone wouldnt mind
    The problem i have is lack of power below 2k revs, i have the third injector changed, i have cleaned the turbo sensor, i did have the swirl valve control rod hanging off, this is now back on and holding next it has to be the egr valve clean.
    So please if anyone can help please get in touch
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Sounds like EGR
    Irmscher Insignia CDTI 130
    WGAF#5
    you could also try the brake pedal method to read the codes yourself
    works on most cars and then you could read the codes at home
    Aug 2009
    Camberley
    Never heard of that could you tell me how to do it
    Blantyre
    http://www.vectra-c.com/forum/showthread.php?t=81742
    Thanks to STE !!
    The porcedure is simple and is done from the drivers seat, with NO equipment.
    Get in
    Press and hold both brake and accelerator pedals to the limit of their respective travels
    Turn ignition key to Position 2, ie dash lights on
    Release accelerator pedal
    Re-depress accelerator pedal to the floor
    Turn off ignition
    Turn on ignition to position 2
    The engine symbol on the dash will then begin to blink
    There will be a sequence of flashes, separated by small pauses between numbers and a longer pause between separate fault codes.
    The number of flashes needs to be counted and thus the 4 digit fault code can be determined.
    EG, if the flash count goes as such
    10 flashes
    small pause
    1 flash
    small pause
    1 flash
    small pause
    10 flashes
    Longer pause
    10 flashes
    small pause
    1 flash
    small pause
    10 flashes
    small pause
    10 flashes
    Then there are 2 fault codes recorded and they are
    0110 (ie 10,1,1,10 flash sequence)
    and
    0100 (ie 10,1,10,10 flash sequence)
    Aug 2009
    Camberley
    Ok will try that thank you, will keep you posted cheers
    Aug 2009
    Camberley
    Ok fixed it, Using help from
    http://www.vectra-c.com/forum/showth...gr+valve+clean
    worked a treat I have a Ultrasonic cleaner at work I cleaned it in, the solanoid was stuck and full of rubbish so had to press out and clean, very pleased with job and car running like new, thanks for help and to the member with the photo instructions.
  1. diagnostic readout
    By gsi-robster in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2012, 18:06
  2. diagnostic
    By mc12 in forum Petrol Engine related
    Last Post: 13th December 2011, 23:41
  3. u480 diagnostic scanner problems
    By dan9895 in forum Engine & Drivetrain
    Last Post: 25th June 2009, 08:57
  4. diagnostic help
    By smartymarty1971 in forum Engine & Drivetrain
    Last Post: 3rd June 2009, 00:29
  5. Diagnostic
    By Ste in forum General Chat
    Last Post: 22nd September 2008, 17:17
