Page 1 of 7 123 ... LastLast
Results 1 to 10 of 62
Thread: removing de-mister grille
    Regular Member storey_3000's Avatar
    May 2006
    somerset
    Question removing de-mister grille
    Is the de-mister grille in/on the dash for the windscreen removable? Or is it bonded in? I've got the most irritating vibrating rattle/noise that stops when you put your hand on the vent, so i figured i would investigate but don't want to break it trying to get it out!
    The centre section just lifts off - that could be where your rattle is?
    As for the rest of it, I don't know. I'll have a shufty on TIS for you.....
    May 2006
    somerset
    Cool thanks duncan. I've tried pulling the centre section out but its still there even with it removed! BTW, what is that thing under the centre section?
    Feb 2006
    Dorset
    Its a centre channel speaker on some cars .
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Its also where the gps thingy goes on the higher spec cars
    Feb 2006
    Dorset
    GPS is built into the base of the rear radio ariel along with GSM antenna there is also another ariel base which has DAB and GSM and also just a basic radio ariel on bottom end models
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Mates 2004 gsi has his in the grill thing (little ball). His ariel is the same as mine (none sat nav sri)
    Quote Originally Posted by DennisTheMenace
    Yep, the centre speaker should be on all models. It's just the rear door tweeters that are extra on other models making them 9 instead of 7 speakers.
    Rushy - I wasn't aware of anything GPS related in there. I thought that was all on the aerial base.
    The only other thing on that centre vent is on top of it - a round red dome. That's the sun sensor for car with Climate Control.
    Storey - I never looked at TIS for you. I'll have a look now.
    its supposed to be a sunshine sensor for the climate control, the little ball..
    ahh..fastest finger first eh D??
  1. Rear de-mister and radio
    By richje100 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2012, 07:37
  2. Replies: 7
    Last Post: 26th August 2011, 20:25
  3. rear de-mister not working
    By AKeeNShoT in forum Vectra C / Signum Troubleshooting
    Last Post: 16th May 2009, 12:42
  4. front de-mister thingy
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2008, 13:45
  5. front de-mister thingy
    Last Post: 6th August 2008, 08:19
