Thread: track rod ends
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    Default track rod ends help needed please!
    after a bit of advice guys.
    took my car in for a little pre mot inspection today and was told it may fail on the track rod ends as they were worn.
    Is there a how 2 on here? cant seem to find one. if not any help would be appreciated. also are the left & right side the same or do i need to different ones? ive looked on abay but im unsure what im buying any linkys to the correct parts i need would be fab.
    Regular Member DaveW555's Avatar
    Cannock
    www.eurocarparts.com just tap your reg in and search for track rod ends
    Sep 2009
    swansea
    Trim : Club
    hmm could have been the tie rod. is there a difference between the 2?
    the one the mechanic showed came from & was attatched to the steering
    Cannock
    The tie rod comes out of the steering rack and is what the track rod end fixes to, apparently quite common for them to fail on vectra's mine had an advisory on them last year, i'll get around to doing them at some point before the mot this year lol
    Sep 2009
    swansea
    Trim : Club
    ok thanks mate. so idealy its best to change both?
    Cannock
    Yeah I would, if one is worn the other will be just as bad, you'll probably need to have your wheel alignment (tracking) reset afterwards unless your very bl**dy lucky.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    After my attempt to change the tie rods and ends I would advise letting a garage do it. They are be a real pain to remove.....have a read.....http://www.vectra-c.com/forum/showth...ght=drag+links
    Sep 2009
    swansea
    Trim : Club
    Quote Originally Posted by John35 View Post
    i am mate dont you worry. my old mans got a garage. ill get the parts he'l fit them. gonnareplace the tie rods too while its appart.
  1. Replies: 5
    Last Post: 15th July 2010, 21:33
  2. Track Rod Ends or Inner Track Rods
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 28th April 2010, 11:41
  3. Track Rod Ends Help
    Last Post: 23rd April 2010, 14:13
  4. Track Rod Ends
    By Cat_J in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2010, 01:14
  5. Track Rod Ends
    By parapaul in forum The 'Off Topic' room
    Last Post: 13th March 2008, 01:05
