Results 1 to 10 of 11
Thread: Brake pad dash light
    KENT
    Default Brake pad dash light
    Hi
    Does anyone know how to turn off the brake pad warning light off using tricks?
    I have had all my brake pads fitted but the light is still on!
    ta
    Regular Member signumturbo04's Avatar
    SCOTLAND
    on the front passsengers side where the brake pad sensor plugs in cut the plug off and earth the wire to the chasis. had to do this on mine cause light wouldnt go off on the dash
    Aug 2009
    LEEDS
    have you bought the right pads with the wear indicator wire?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    just join the pad sensor wires
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    a new pad wear sensor is only 8 quid
    KENT
    thanks guys!
    Jul 2009
    The Rift, Cardiff
    I thought the sensor seems quite useless really. Only on one wheel and the rear pads seem to wear 2 - 3 times faster than the fronts, so making visual checks necessary anyway. Or is it just me?
    (I wouldn't rely on the sensor, the sound of metal grinding when you push the middle pedal is a better indicator )
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Sensor is only on the front wheel anyway.
    Logic behind this is that a mechanic would check the rears at the same time but also, the rears wear at a much lower rate.
    Or you could have a pre-facelift Life model like mine, whereby they did away with the sensor wire altogether!
    Quote Originally Posted by John C S View Post
    Or an 07 Elite 3.0 V6 like mine - and not have it either...
    Quote Originally Posted by shearzy View Post
    They are separate parts
    The Vectra B was the same, the base models did not have a front brake pad sensor, however there were two wires
    having two wires was fairly pointless as in most cases both had to be replaced; it was very rare for just one to wear out
    I agree though, the rear brakes wear out faster than front brakes, but that is simply due to the poor heat disappation
    I have had that on all the my cars with rear brake discs (rather thn drums)
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. oil light on my dash
    By accveccysriturbo in forum Engine & Drivetrain
    Last Post: 14th January 2013, 18:26
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Brake pad dash warning light
    By APJ in forum Suspension, Wheels & Brakes
    Last Post: 10th January 2007, 09:08
