Thread: Oil Change 1.9 cdti
    east yorks
    Default Oil Change 1.9 cdti
    I am thinking of doing an oil and filter change on my 150 bhp cdti.Can some one tell me where the oil filter is located and is the process easy ?
    I have no special tools, do i need any.
    All advice greatly recieved.
    Apr 2009
    norwich
    i also want to do an oil change this weekend on my 1.9tdi cannott see the filter,and it has 2 seals in the box help please anyone ????
    cheers
    chris
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Very easy to do, the filter is at the back of the engine and accessed by the access flap on the splash tray, just need a 32mm (iirc) socket to get that off.
    2 seals in the filter box? Just put on one new one, thats all I did and its been fine.
    If you have access to wheel ramps or axel stands it makes life easier, or even a pit!
    You can take the splash tray off or you can just unscrew the access flap - you'll see the tray is held on with torx screws and the flap is just a phillips driver.
    My House
    Hi,yes 32 mm is correct,there are two seals on the housing so best to renew them both as you have the housing off.
    The drain plug is a 13mm and sometimes is very tight so make sure to have a good position on it before you give it some!!
    If you look on the filter housing at the back of the engine you will notice a little'spout',if you put some garden hose on it,loosen the filter until oil starts to come out then it will save you covering the down pipe with oil.
    When it stops pull out the housing and filter.
    The vauxhall stated oil amount is 4.3 litres...hope this helps.
  1. oil change on cdti
    By lutontownfan in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2010, 14:37
  2. CDTi Oil Change!
    By RobW in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2010, 20:01
  3. V6 Cdti Oil Change
    By BIG NEIL in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2008, 12:59
  4. Oil change cdti 150
    By DG01 in forum Detailing and Car Care Discussion
    Last Post: 29th February 2008, 22:38
  5. 1.9 CDTI 16v OIL CHANGE
    By GSiSnash in forum Engine & Drivetrain
    Last Post: 29th January 2008, 14:43
opel vectra c 1.9tdi oil change
