Thread: Bleeding the coolant
    Thatcham, Berkshire
    Default Bleeding the coolant
    Right, I'm going to finally get round to fitting the new Thermostat at the weekend! Whilst at the stealers I asked the service manager if the system (CDTi 150) was a 'self-bleed' system and he said "NO" and wouldn't tell me how to bleed it!?
    Anyone know how?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    He's talking out his rear end. It's a high pressure pump driven system with an expansion tank specifically designed to allow excess pressure (and air) to escape.
    Thatcham, Berkshire
    That's what I thought
    So, I should just do the thermostat and keep filling the expansion tank whilst the engine is funning up to the MAX guage?
    Regular Member DaveW555's Avatar
    Cannock
    Yeah just fill the system up with coolant, run the engine up to temp (leave the cap off the expansion tank) keep topping up the level as necessary and put the heater on full, when the heater blows hot, do a final check of the level then put the cap back on. Turn the engine off and let it cool down overnight then check the level again, job done.
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    140 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Holy thread revival!
    So if this is the way to bleed a cdti then why have I found other posts saying you have to bleed the coolant with the small screw on the pipe at the front of the engine?
    whats the correct method lol
    Teapot Tuned 260/300
    Eibachs B8's, Hansen drl/fogs, fully loaded factory options
    https://www.vectra-c.com/forum/calendar.php
    Full Member
    Dec 2010
    Glasgow
    Vehicle : 1.9 Cdti Signum
    Engine : z19 DTH
    Mileage : 99000
    cobwebs?
    what they said have you got a 150 ?
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by Dog_Book View Post
    What Ian Said.
    Quote Originally Posted by Ian-Highlander View Post
    Regular Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    6 Post(s)
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    Leave that screw alone, it's as much use as a chocolate teapot
    Oct 2013
    Derby
    140 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Thanks boys! I'm good with mechanics but with no manual you'd assume it's a bleed screw I wonder what it's for then lol?
    well since the new stats been fitted for 3 months if assume it's already self bled so it must be faulty. I can't think that running the engine with the expansion cap off for a while would make a blind bit of difference
    May 2012
    6 Post(s)
    Trim : Exclusiv
    it is a bleed screw, its just pony
  1. Bleeding Vec. 150 ?
    By mickyh7 in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2012, 20:03
  2. bleeding bleeding and adjustment
    By noudder72 in forum Suspension, Wheels & Brakes
    Last Post: 26th December 2011, 11:29
  3. Bleeding The Coolant...?
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2010, 18:45
  4. Bleeding Brakes - Few Q's
    By yoclick in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2010, 17:10
  5. Diesel bleeding
    By craigbarlow18 in forum Engine & Drivetrain
    Last Post: 25th September 2009, 19:31
how to bleed coolant on vectra c
