Thread: Taps......... Again
    Regular Member Damian's Avatar
    Market Drayton
    Default Taps......... Again
    After the useful help I received for my kitchen tap (which now no longer drips) I thought I would ask about my bath/shower mixer tap
    It is some 10 years old now and has 2 issues.
    The first is that the hot tap is very stiff to turn on, it turns part way, then I really have to turn it hard to open it the whole way. What is causing this and how do I fix.
    The second problem is that when the taps are on and I push down on the central plunger to divert the water to the shower head, water comes out of the shower head but also still comes gushing out of the tap. Again what is the cause and how do I fix.
    Apologies for the tap not looking shiny !!!!
    What are these taps called. I tried googling "bath mixer/shower tap not diverting all water to shower head" and unbelievably didn't come up with many helpful hits !!!
    Damian
    Worcs/Staffs/Westmids (ish)
    New taps TBH
    West London
    the water coming out of both the taps and the shower head id guess is down to a part inside that shuts off the water to the taps when the buttons pressed/pulled probably degraded or snapped.
    Mar 2007
    North East
    The sticky hot tap is probably the valve and the diverter for the bath shower is probably perished.
    Prolly cheaper to get a new tap.
    East Midlands
    iv'e had this before,and allways seems to be the hot water tap,unscrew and remove the body,then take it all to bits,clean with wd40 and put it all back together again should to the biz,usally caused by hard water furing...?Do you live in a hard water area Damian.
    Norwich
    Trim : SXi
    Engine : 2.2
    Lime descaler squirt it down the shower hose, works a treat
    Market Drayton
    Guys, I have solved the stiff tap issue, cleaned the gland out it works a treat now thanks.
    Any ideas how to get the plunger section apart for the shower head, I just can't fathom out how it comes apart
    Damian
    Regular Member vauxhall-john's Avatar
    fife, scotland
    try removing the shower hose and see if the plunger part is held on with a round internal circlip??
  1. Kitchen Taps Query
    By Rebellion in forum The 'Off Topic' room
    Last Post: 30th January 2013, 08:07
  2. Taps talk test
    By baz2003uk in forum Signature & Avatar Testing
    Last Post: 28th April 2012, 20:58
  3. basin taps cp fitting and trap all new
    By barrymanalow87 in forum General items for sale
    Last Post: 9th March 2010, 00:17
