Thread: Squeeling brakes
    Regular Member sy_uk's Avatar
    Newcastle
    Default Squeeling brakes
    I had new mtec drilled + grooved discs fitted with pads about 2 months back (pads were from ebay, they have no gap in the centre of the pad)
    Since fitting, the brakes have squeeled, really loudly, i thought it might bed in and stop
    The garage that fitted them said it was the pads (faulty) and i should get new ones, he also said he would try re-greasing but would charge so i basically said eff off
    Can it just be down to crappy pads that i've bought? It doesn't really make much noise at speeds over 40ish
    Newcastle upon Tyne
    Mine are the same mate, I had VX discs and pads fitted 18 months ago loads left on pads but have squeeked since done! Its somthing I just live with but would love to find a 'easy fix'!
    Regular Member paul.sessions's Avatar
    leighton buzzard
    i got the mtec disks with ebc brake pads they squeak too think it just the material the pads are made from these days
    Regular Member DaveW555's Avatar
    Cannock
    Have you tried taking the pads out, cleaning the carrier with a wire brush/emery paper, then copper slip the pads on the edges where they meet the carriers and on the back of the pad? Usually shuts them up either that or its mickey mouse pads.
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    I have these mtec discs but with mintex pads and have no squeal whatsover, its seems its a great combination..
    Regular Member Innes's Avatar
    Plymouth
    I replaced my pads and discs on my megane but got them cheap off the net. The pads didn't have any shims on the back of them and it began to squeal like a ***** after a few miles.
    For those who dont know, shims are a kind of pad on the back of the brake pad. On really old cars you used to have to buy them separately but these days manufacturers glue/weld them on the back of the pads. Its made out of a softer metal or sometimes a hard rubber and this is what the brake piston pushes into. its stops the piston and pad vibrating under braking which causes a squeal noise.
    I took the pads off again and put a bit of copper grease on them and it stopped the squealing for a week but it eventually came back. In the end I bought Genuine Renault Pads with the shims on the back and it cured it instantly.
    I would take your pads off and look at the back of them. If they dont have any shims then you'd be best binning them and getting a pair that does have them.
    WGAF#5
    as above a noise supression shim (spring) will help remove the resonance from braking and the squeal which should only occur under light braking
    another option is to remove the pad and chamfer the edges so that the pad has a smaller surface and this will hopefully increase surface pressure under braking and reduce the noise
    this is a problem with most brake pad /disc manufacturers now as they have removed the asbestos that used to help lubricate the friction caused by braking and now there is just a higher concentration of metal on metal
  1. Squeeling sound :/
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 13th October 2012, 07:59
  2. Squeeling from engine
    By Gortreck in forum Engine & Drivetrain
    Last Post: 14th December 2010, 14:51
  3. Engine Squeeling when started, hot or cold
    By benparker in forum Engine & Drivetrain
    Last Post: 2nd August 2010, 16:56
  4. Squeeling Brakes
    By Griff72 in forum Suspension, Wheels & Brakes
    Last Post: 5th February 2010, 19:54
  5. Brakes squeeling
    By S14RRJ in forum Suspension, Wheels & Brakes
    Last Post: 23rd April 2008, 00:44
