Results 1 to 3 of 3
Thread: help wet passengers floor front and rear
    hertfordshire
    Default help wet passengers floor front and rear
    hi im new at this havent long had my vectra c eleite i have the front passenger sfloor damp and the passenger rear soaked cant find any leaks wondering if it could be the air con drain blocked ive jacked the car up water trickled from the chassis but no sign of the air con drain ive switched it off for a couple of days along with leaving the windows open at work to dry her out but feels quite wet by the time ive travelled home again any suggestions very welcome thanks
    Full Member spennny's Avatar
    Blantyre
    Lift the scuttle panel mate and make sure the drain isnt blocked, if it is that will cause the wet footwell at the passenger side
    hertfordshire
    thanks mate ill take a look at that fingers crossed
  1. help ( water front passengers foot well )
    By booner in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2011, 15:16
  2. installing a power-outlet/cig lighter rear passengers
    By tinus71 in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2010, 09:25
  3. play in front passengers side wheel bearing
    By wilsons 1.8sxi in forum Suspension, Wheels & Brakes
    Last Post: 22nd June 2009, 17:14
