Thread: Odd message?....
    Regular Member bigdave1701's Avatar
    York
    Default Odd message?....
    Just popped out to the shops. just after pulling out onto the main road I got a message in the dash saying "Check Left Brake Light". I assumed it means a bulb has blown but when I checked, all the braking lights are working fine? Its not come up again but it has now got me thinking, is there any hidden meaning behind this message? Is it a sign that something is shorting out or there's a lose connection?
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    What happens is with the heat they reweld on so it will more than likely blow
    Irmscher Insignia CDTI 130
    Jun 2006
    Kirkintilloch, Scotland
    I've had the warning a couple of times.
    On both occasions couldn't find anything wrong but shortly after, the reported bulb did fail.
    Dave
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    It can mean the resistance reported by the bulb check system has changed to a point where although the lamp still lights, it's on it's last legs.
    The same can also happen when you fit 'cheap and nasty' bulbs - stick with good quality kit Ring, Osram, etc.
    York
    Cheers. Ill stock up on some spare bulbs ready!
    Regular Member old cruiser's Avatar
    slough
    Mine did the same thing with the brake light , but hasn't done it again for a month or so now.
    Cheers Pete
    Regular Member Marcosuk's Avatar
    Fife
    I took all the bulbs out the holder & cleaned the contacts, which worked for me.. Also, then the vecs blub blows does it not use the driving light as the brake??
    Regular Member madman's Avatar
    nottm
    it will use another bulb to compensate for the blown bulb. look closely and you'll notice its a different bulb coming on.
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Really not trying to be funny but I had the same and both lights were OK. Took me a good 20 minutes to see the middle one had blown!
  1. First Message!
    By meridian9 in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2011, 17:09
  2. message
    By dave_sri in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2010, 13:55
  3. Message to Mum
    By Gaz the Cab in forum Comedy & Humour
    Last Post: 29th January 2008, 12:30
  4. Message Help
    By ace in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2007, 20:04
  5. Message for all!
    By AJA in forum General Chat
    Last Post: 18th September 2005, 19:50
